On 02/02/2024 at 8:05 PM, joshuaho96 said:
You are not removing the oil pump without pulling the engine. Just isn't happening. It is theoretically possible, in practice a 700 pound boat anchor is going to be hanging over your head and the slightest mistake will severely injure you.
I have done very annoying jobs that should require pulling the engine but I didn't. I get the mental block when it comes to pulling engines, especially because it requires a ton of shop space most people don't have. This is one case where you need to pull the engine.
Ok, will it be worth it to put on a fluidampr to prolong the life of the stock pump and gears?
Edited by The Skyline Guy r34
Probably, especially if the stock damper is 25+ years old. I don't think it will do much for the oil pump which mostly dies to cavitation but the rest of the engine will appreciate it.
  • Like 1
I have to add, I've run two(small sample I know) RB26 with stock short nose r32 crank and stock oil pump gears at high power over many years without issue.
I do always put on an ATI damper and manage limiter.
650whp - run 9's and has been in my hands for 16 years and counting.
780whp - driven weekly, roll raced etc and been going 4 years and counting.
This is no guarantee for you but it is a counter to the RB's smash gears by just looking at them :)
  • Like 1
Ok, so you would say its worth getting a damper?
It's always been my policy but I have no comparison motor without one to compare it to.
As others have said, the one on your motor is also for sure trashed by now.
  • Like 1
I will bet if you've never replaced your damper the one on the car is absolutely wrecked and you should think about replacing it regardless of how much power you want to make.
  • Like 1
  • 1 month later...
You should wait to get the billet gears like the guys are saying, but removing oil pump in engine if you ever need to for some reason is possible. I coincidentally just watched this video the other day. I bought gears without knowing how much trouble removing the pump would be so I've decided to just sit on the stock one till it goes and then go down the rabbit hole of pump, gears, crank collar, head drain, pan, etc.
well, good on him for proving its possible, but it is still not how I would do it. That vid doesn't show probably the trickiest bit with cleaning and resealing the sump (although he does state it is done and not leaking, wish I could say that for mine :rofl:)
My view is still that replacing an RB oil pump is an engine out job, and you probably shouldn't do it without putting on a larger sump and doing some oil return mods.  There is very little safety gained by moving to billet gears alone, and you really can't put in a higher flowing one without making other engine out changes. And of course, in a 32 you still have the short oil pump drive which is by far the biggest issue with pumps. Also, the time to do it in the car is almost certainly longer than the time to R&R the engine and doing it on a stand.
Just stay off the limiter with a standard engine. Or really, any engine, these things are expensive these days
  • Like 1
Once you’ve pulled the box, the crossmember. The drive shafts and what ever else, it would have been quicker to just pull the engine
3 hours ago, Dose Pipe Sutututu said:
But but but... It's when I know it's time to change gears or reached my desired max speed in 4th (as I'm still using the factory dash lol).
Yeah, I wish my redline in 1st was about 10k. It comes up and yells "Surprise mutherf**ker!" whenever the red mist comes down at the traffic lights.
  • Haha 3
And now you have 500+ pounds of engine hanging basically in free space threatening to split your head open. Not worth the hassle. And I would go as far to suggest that doing turbos with the engine in the car is not the worst idea in the world if you can afford to take your time and don't have space for a car and an engine.
Doing turbos in the car is a piece of piss, anyone that pulls and engine out to do turbos on a gtr shouldn’t be allowed to work on cars
  • Haha 1
 Share
    • The stock one will outperform any aftermarket standard position exhaust manifold. If you don't believe me, do a back to back test (same turbo, same boost, same timing) and you'll be super surprised.
    • Any recommendations on a decent replacement manifold that doesnt break the bank or require additional mods for the stock turbo setup? I figure if I'm going to pull the manifold off anyway to fix the studs might as well replace it.
    • So I checked the turbo out today. Very minimum play at all just enough for the oil to take up when it's running. I did find an exhaust leak at the manifold. 1 stud all the way in the front is missing and the one all the way in the back is broken off. Front has visible signs of an exhaust leak. I'll fix that soon but that's not my problem still.  I also found that the nipple coming off the turbo had the hose capped off and a hose ran from the j-pipe by the bov going to the wastegate. I removed that hose and capped that nipple and put the turbo nipple hose back on the wastegate.  There was a ton of oil residue all through the charge side of the intercooler piping going to the throttle bodg. I'm thinking that's from the pcv. Doesn't seem to be coming from the turbo that was all clean on the pipes side.  Haven't had a chance to check fuel pressure yet, haven't had time been having to pull a lot of doubles at work. I did pick up some carb cleaner to clean the iacv but wanted to make sure I had a fresh gasket in case the old one rips when I pull it off.  I'm waiting on a MAF that was supposed to be here today but delayed to Monday. Have a double Monday and Friday and work all of next weekend so going to try to find some time in the middle of the week to try that out. Did about a 10m trip around the block today and towards the end the issues were coming back. Fingers crossed on this MAF but if not just going to throw a fuel pressure gauge in and see where I'm at.  Did notice today that I can definitely hear the injectors pulsing. Very audible clicking coming from them. Assuming that's normal? Should also mean CAS is functioning somewhat properly. After it warmed up when I started it the intermittent misfires came in again. Did start doing that before it was fully warmed up.
    • This morning I carefully reinstalled the manifold and started looking at a couple of things I need to do.  Heat wrap arrived sometime today so I popped into the shed with the missus dishwashing gloves and started wrapping the first half of the dump and the screamer/plumb back.  Once I do the second half I'll be able to final fit the turbo and exhaust up.  Also pulled the harness out today and started terminating it at the ECU end. A connector is done, just need to run the remaining wires that arent in the harness - 12v, gnd and couple I/O
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
