Hello again, I have a 1991 r32 gtr that I’ve modified and dynod. The power it gave me was a bit disappointing with 533 wheel horsepower and 444nm torque on a dyno jet dyno. On a heavier dyno it would read to about 433 wheel horsepower. I say disappointing because it currently has :
CP oversized 87mm pistons
Eagle H beam rods
Extended crank with the nitto collar
stock oil pump (nitto on the way)
stock sump (leask sump on the way)
Garret G35-900 single turbo
^ With 26psi of boost (1.6 bar)
6boost v band manifold
turbosmart 60mm external wastegate
Brian crower 264 cams
tomei gaskets all around
arp head studs
dual wallbro fuel pumps
dw 1050cc injectors
greddy radiator
metal Intercooler pipes
nismo thermostat
offbrand fuel regulator (tomei regulator on the way)
ngk 7’s spark plugs (tuner refused to tune with 8’s for my car)
Running on a motec m800
I know that running on e85 and opening the rpm to around 8500 instead of my current 7200 will also boost my power yet will it increase a lot or just slight because people like cardoGTR and andrew Hawkin from motive were all running around 600 wheel horsepower on the same setup as mine. Any feedback on what I’m missing?
thanks
https://www.sau.com.au/forums/topic/485443-rb26-expected-power/
I'd say post the dyno sheet so people can look on it, but you already know all dynos are different.
I mean 26psi on Petrol/Gasoline seems pretty up there, and if you aren't revving it out then unless your torque is really nosing over, then of course more RPM will equal more HP.
If you think E85 will make the difference between 533whp and 600whp the answer is absolutely yes. Given the only thing that makes power is the turbo, and you've got plenty of boost in there, it all seems semi reasonable to me. Curious to see what other people say though.
The one thing that never lies is MPH at the drag strip. See what you trap. (ok, it can lie a bit with altitude and conditions etc)
  • Like 2
Any chance you know how much timing your running to make that power?
Did your tuner say what the limitation was when they were tuning (eg knock? boost control issues? etc)
And final thought, if you are able to easily source e85 where you live, I'd 100% recommend using it. But before you go back for the flex tune, you probably want to get some bigger injectors. On e85 I see you maxing out those 1050cc injectors real quick.
  • Like 2
As already mentioned, we need to know what was limiting you. Fuel? Knock? If I understood correctly, you have your rev limiter at 7200rpm?  If so, that is very low/strange, and your tuner would have made a point to discuss it. A G35-900 will continue to make power north of that.
What gas and where are you located?
Edited by TurboTapin
  • Like 2
I don't understand how a heavier dyno will make less power, but anyhow let's take your first figure. You're making 397kW on normal 98RON.
That's a pretty decent number, considering you'll be pretty knock limited with your fuel choice.
Throw in E85, more timing, more RPM and you'll go over 500kW with ease
  • Like 1
  • Thanks 1
2 minutes ago, GTSBoy said:
I expect it's just slang from somewhere for a low reading dyno.
Probably originates in the US where the inertia dyno is king and some actually might be "heavier" than others.
what a load of street takeover baloney, of course it's some US jargon or bs.
what exhaust, intercooler, turbine housing?
I don't get this part ngk 7’s spark plugs (tuner refused to tune with 8’s for my car) why is the keyboard operator telling you what parts go in your car comes of as controlling, controls your engine, your tune, your horsepower.
  • Like 1
He limited my rpm because of some ptsd he had from a previous rb26 getting head starvation, and I’m located in Dubai using pump gas. We made more power running a bit more lean but for some reason my car did not like being that lean
Stock intercooler and 0.83 housing, everybody I know with a gtr and running north of 20 psi has 8’s for plugs and for some reason my tuner refused to tune my car if I went to 8’s and said he’s not responsible for any damages that’ll happen. That freaked me out a bit and made me stay on my 7’s.
yeah your correct i meant it as a low reading dyno and not a “heavy dyno” that’s just the slang people said to me so I repeated it here
My tuner said my timing is 12 on one bar of boost.
I like the drag idea, and unfortunately I didn’t take a picture of the dyno sheet. I’ll try out my luck on the drag and see what I clock
Rb's have issues with bottom end starvation, not head starvation. Which either way, you probably wouldn't ever see on a dyno. Strange...
What's pump gas for you? Octane rating?
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
