The reason I made this thread was to try to get some useful info as all of the older threads only have tidbits here and there, while I do appreciate banter and suggestions of shoe horning V8s into cars, for the sake of someone trying to make a decision on this topic - is the general consensus that you really don't need to convert to solid lifters unless you're chasing wild above average power and rpms?
options -
Stick with hydro lifters possibly make 450kw at 7500rpms assuming all the right supporting mods for that goal
Spend the $600-800 for the Solid lifters and find out how hard it is to set the clearances and what else needs replacing around them
Neo head - possibly will cost more depending on the head prices at the time
Throw away RB or buy a BMW 😆
There's a lot of the solid kits getting around from different manufacturers so someone must be doing the conversion
30 minutes ago, Yeetus said:
Haha that is a wild idea, how about a banged up R33 and a case of beer? Mates rates? 😁
No more 90s JDMs for me, just want 4 door cars that won't attract cops.
Wouldn't mind a Hako or a 240Z all motor but modernised (big comp, big cams, ABS, DBW, dis dat).
You can definitely do 450kW on the RB25 non-NEO head, plenty have.
The $600 to $800 conversion will end up costing you much more I suspect, I believe you will require machining.
NEO head has the lowest barrier to entry.
My 2c?  buy a BMW 😆
1 hour ago, Yeetus said:
options -
as hydro lifters/ head will do 450kw no probs - went through many race engines at that power and 7.5 - 8 K rpm and the head was never the problem  especially if a street car you not going to push it hard enough consistently enough either
solid lifter conversion is big $$ not $600 - $800, do this and that and put em in
I know someone doing nearly 800kw on poncams 😉  well a few tbh
  • Like 3
3 hours ago, The Bogan said:
The way I see it is if people are happy to spend 10's of thousands of dollars on a build, a couple of thousand to get it engineered is good insurance
The funny part is, an engineer's cert still doesn't actually make the car legal. Interesting part on that :/
IE, even some cars from the factory are defectable as they sit in the showroom. So even stock doesn't mean legal. :)
1 hour ago, Dose Pipe Sutututu said:
btw... here's a fun quote I got back in the day (using a NEO head and going shimless):
a bit different initial requirement
Just had a chance to have a read of this, exactly the type of info I was after thanks for that! Amazing that thread never showed up in search
Yeah I'm definitely getting swayed away from the solid conversion, plenty of people getting impressive results without it
  • Like 2
And the rules change with time ...but speaking to the premise you raise here, some of us old farts will remember seeing every police motorbike with a rubber rear mudflap extension, fitted to the end of the rear mudguard. This was due to an ADR that required the rear mudguard to extend lower than the rear axle (iirc 15 degrees lower as measured at the axle center line)...it was changed in '89 updates, but basically before that date, any road going motorbike was technically 'illegal' (unroadworthy) ...the whole area is a real prickly pear... 😃
  • Like 1
Things change over time but all that matters though is that the vehicle is compliant with the rules that were in place for the year when it was constructed.
Go back far enough, cars didn't have seatbelts or catalytic converters. You can still legally drive them without a seatbelt or cat fitted.
It's not like vehicles need to be updated every year to match the updated ADR's to stay road legal.
I'd say the most common scenario is the car's build has 2 stages, all work that can be engineered is done first. The car is passed then the second round of mods start, all the ones that can't be engineered lol.
It still doesn't matter to the eye of the law. It's all those annoying grey areas. Engineer the car under a specific area, but that same thing is still illegal elsewhere. Hence, still not legal.
We are talking about different things, all I'm saying is there are plenty of people out there that don't stop modifying their car after it has been engineered.
  • Like 1
1 hour ago, pogman said:
Poncam the world
If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.
Tomei USA is not the real OG Tomei.
Random rant over, fk the US of A, bunch of c u n t s.
  • Like 1
  • Haha 2
It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
Is the UP Garage in the US of Ayyeee even the real UP Garage?
I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.
There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
I guess that's what happens when someone can't convert metric to freedom units to machine something. 😛
  • Haha 1
Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon?
NASA has their brain switched on and uses the metric system.
  • Haha 1
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
