Had a little bit of a dissappointing result at the SAU:SA Dyno day today the M35 only pulled 126 KW :happy: It was on a mainline dyno, which they say under reads - but even so, would've liked a few more numbers. At least Ive got a baseline for future comparisons though.
i thought m35's ran 12psi stock?
you didn't even make it to 10
if its highflowed, its good to about 20psi but 14 will be safe with the stock ecu/boost cut
that is nuts Scott.
That would be a real handful in the wet.
Its quite docile actually, only spins up inside wheels in first, I would be stepping out sideways if it had an lsd though.
Of course I dont drive like Craig either. :geek:
I have the Nismo in my car at the moment and it comes on very strong in the lower rpm and in the Wet + 1st gear + a bit of fun = a very sideways car out of round abouts.....lol
Of course I dont drive like Craig either. :)
Oh you will....once you find the love of the LSD and loose the single spinner!!! :P
LOL....at least you can get sideway's at low speeds....I have to wait until I hit 60-70km's!!....lol
just love the way it stay's at about 1000nm's.......nice steady curve up to 300AWKW's as well.
Try that with a RB tractor motor :P
you realise thats tractive torque and the only way to measure engine torque accurately is on an engine dyno? so its not really 1000Nm
still an impressive result, should be even better if you guys get your ecu re-mapper sorted
Yep, tractive effort, and 200nm more than the 2j manual supra that was tuned before mine.
V6 FTW... :P
I have given up on the remap, mainly because I will be changing to the VQ35 soon. It looks like I am going down the Haltech platnum pro path.
Awesome result man... especially for a car so well behaved. (Yes I'm jealous)
Maybe you need to get it in an engine dyno to see exactly what nm it is pushing?
Edited by iamhe77
Probably easier to just get an RB powered car of similar output on the same dyno for a comparison.
would be a lot easier
but i think the tractive torque is affected by gear ratios, tyre size and a few other things so it may not be an accurate comparison
I think as long as the speed to revs ratio is the same it wont matter. Different gears, diff ratios and tyre sizes will change everything, not to mention auto box and awd etc.
if only i had the front hubs... we would know in 5 mins.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
