Had a little bit of a dissappointing result at the SAU:SA Dyno day today the M35 only pulled 126 KW :happy: It was on a mainline dyno, which they say under reads - but even so, would've liked a few more numbers. At least Ive got a baseline for future comparisons though.
i thought m35's ran 12psi stock?
you didn't even make it to 10
if its highflowed, its good to about 20psi but 14 will be safe with the stock ecu/boost cut
that is nuts Scott.
That would be a real handful in the wet.
Its quite docile actually, only spins up inside wheels in first, I would be stepping out sideways if it had an lsd though.
Of course I dont drive like Craig either. :geek:
I have the Nismo in my car at the moment and it comes on very strong in the lower rpm and in the Wet + 1st gear + a bit of fun = a very sideways car out of round abouts.....lol
Of course I dont drive like Craig either. :)
Oh you will....once you find the love of the LSD and loose the single spinner!!! :P
LOL....at least you can get sideway's at low speeds....I have to wait until I hit 60-70km's!!....lol
just love the way it stay's at about 1000nm's.......nice steady curve up to 300AWKW's as well.
Try that with a RB tractor motor :P
you realise thats tractive torque and the only way to measure engine torque accurately is on an engine dyno? so its not really 1000Nm
still an impressive result, should be even better if you guys get your ecu re-mapper sorted
Yep, tractive effort, and 200nm more than the 2j manual supra that was tuned before mine.
V6 FTW... :P
I have given up on the remap, mainly because I will be changing to the VQ35 soon. It looks like I am going down the Haltech platnum pro path.
Awesome result man... especially for a car so well behaved. (Yes I'm jealous)
Maybe you need to get it in an engine dyno to see exactly what nm it is pushing?
Edited by iamhe77
Probably easier to just get an RB powered car of similar output on the same dyno for a comparison.
would be a lot easier
but i think the tractive torque is affected by gear ratios, tyre size and a few other things so it may not be an accurate comparison
I think as long as the speed to revs ratio is the same it wont matter. Different gears, diff ratios and tyre sizes will change everything, not to mention auto box and awd etc.
if only i had the front hubs... we would know in 5 mins.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
