Spotted a couple of stageas today.
First one was a white c34 at Beaurepairs Maroubra, sorry I couldnt stay and chat, was running late enough for work as it was.
Also followed an M35 coming out of Bunnings Crossroads/Casula this arvo around 4pm. I was in a ford ranger and not the stagea.
Yellow Stagea on Happy Valley drive around midday which black wheel arch moulds and black Dayz sticker down the side =)
Saw that one too, looked nice but the dayz sticker was a bit over the top.
Spoted Duncan yesterday morning in his white Volvo at JustJap giving his credit card some workout. :rolleyes:
Nice brakes on that Volvo tough.
Cheers
Dave
Good to cross paths again, it's been a while.
The brakes are actually why I was there..... while they do technically "fit" under the current rims, they are so close that you can't put balancing weights on the wheels, and it's finally tipped me over the edge to grab some larger wheels.
Did you get th oil change done OK?
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
    • Are you using the factory rail?  Is there any reason you don't want to use one of the two you already have, they don't have to attach to the fuel rail directly.  If you 100% must have a FPR that directly bolts to the fuel rail, you could get a Radium setup. I use a radium fuel rail and the direct mount regulator, it is quite a sexy setup.
    • https://www.google.com/search?q=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&sca_esv=6710113de42d5150&source=hp&ei=GhPbaNHfNZeinesPyPqEiQc&iflsig=AOw8s4IAAAAAaNshKnLkjQGMWYT5EyclmXEJm8ZXSWDb&ved=0ahUKEwjR1JOCjf-PAxUXUWcHHUg9IXEQ4dUDCCE&uact=5&oq=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&gs_lp=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_EFhqEHecdnjv2SBwYyLjU1LjGgB7XnArIHBjAuNTUuMbgH4UXCBwgwLjUuNTEuMsgHiQI&sclient=gws-wiz
    • I had the fuel rail out to check the injectors before getting the ECU reprogrammed. The guy said that the injectors were fine, but the regulator was cactus (leaking fuel out the vac port, randomly changing pressure. I decided to replace the FPR with an adjustable unit. I have purchased 2 now, and neither has an appropriate adapter to fit where the FPR mounts. I need advice on where I can get an adjustable FPR that will simply drop in on a RB25DET. TIA
