Silver M35 ARX Four on the Monash this morning. Looks like we wer both headed to the airport this morning. Followed each other right up the Tullamarine.
Good to see you Chris!!! Was like driving into a mirror!!
Interesting to see your M35 and Nissmo badging rather than the normal Stagea and AR-X ones.. Was picking up my sister and her kids.
Car had the M35 and Nismo badging when I bought it.
I'm going to take of the Nismo badge, it's a bit silly really.
Hope to see you around some more.
spotted a shitty little white stagea s2 Dayz with white volk rims parked in 39 herbert st, st leonards :P
In front of Wescon Group. i was doing my pickups from there, i even got a photo.
UMad Bodella? XD
not as cool as my white bomb :D
p.s as i cruise through sydney in my cool Mail Call van in ma little Red Mario hat, i now see at least 15-20 stageas a day, its getting out of hand......... i cant keep up
Think your cool eh?
You got nuffin, I say nuffin on the Mail Call Stagea!
:P
I want pics of said 15-20 Stageas...
Grey C23 S2 on the going South on the harbour bridge this Morning at 8.50.
You spotted a Nissan Serena ?! Wonder if it was the SR20DET model ?
To quote wikipedia "Nissan produced a version with the turbocharged SR20DET to carry people very rapidly"
Or was it the diesel model which "Auto Express once named the Serena as the slowest passenger car in the benchmark 0-60 mph (now 62 mph) test, with the 2.3 diesel version (added in the mid 1990s) taking 27.8 seconds to reach that speed."
Obviously I am shit stirring and realise you just made a typo :D
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
