spotted a silver M35 RS/RX at about 11am on Stacey St by Stevens Reserve in Bankstown.
and also 3 M35's at the dealer on Milperra Rd, Milperra.
yeah, they have been there for a while now, you work in that area? ive spotted you a few times around there i think.
there's a few in milperra/revesby area. a black AXIS, a white RS, my RX, and 2 C34's.
in a company vehicle so it wouldn't have been me :P
spotted a white C34 at 6:45am on the corner of Cobbity Rd and The Northern Rd (Oran Park)............... looked a bit like Ryan's Stagea cos it had white rims but was still a bit to dark to see clearly at that time of morning. :action-smiley-069:
oran park makes me sad
Quoted for truth.
"Own a piece of motor racing history; live on Brock Drive" :rolleyes: Thanks for contributing to the destruction of a perfectly good racetrack.
If I ever have the misfortune of meeting anyone who proudly admits to living there; I'm gonna punch them in the throat.
there was a silver m35 at tyres for less on woodville rd he was on the next hoist to my foulcan .i brought his 18x9s tee hee not sure if ill run them yet they need a reco and new powder coat but the price was right
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
