spotted white m35 stagea RS or RX in intial D stage five ep6 (17:34) lol
HA! it's white too. Easily THE best colour. :yes:
Also an interesting fact, the 'a' at the end of the word stagea is actually for 'advance'. So that's how they came up with the name apparently.
skids were pretty minor. I'll bring some maccas trays to texi.
I was surprised with how many stagea owners I spotted without stageas :angry: Can't beleive Alex didn't go for the pink wrap on his bonnet
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
