I had "No Bullshit Imports" (on the Northern Beaches) change my turbo recently. Nice blokes there, really know their stuff.
Although they take a bit longer to do stuff, their excellent hourly rate more than makes up for it. They don't charge any more (or less) if they are doing something for the first time - they will tell you up front (hence the name 'No Bullshit Imports")
They are more than capable and really looked after me - Even had a beer with them after the job.
Cheers
  • Replies 75
Cheers
Brendan, drinking a beer by yourself after you've changed turbos, still counts as drinking alone! Despite the 'work' completed prior to the drinking (or was it during?)...
:D
Richard
As i am a mechanic my skyline wont ever see a workshop, i have seen to many dodgy things in my time although yes, some of us do try to do a good job and dont overcharge. I look after a number of friends skylines, supras and other imports as well as many more mundane vehicles and they all run beautifully! Unfortunatly its true that a good mechanic is very hard to find so when you do find a one that is honest and knows his stuff stick with.
Chris.
Well I did actually change my oil (I'm not a complete halfwit). However, it wasn't simply the red light on the dash for oil, it was some other indicator below my steering wheel. That's why I was slightly interesting as to why it wasn't going off. Turned out it was just an aftermarket thing which was basically useless and displaying nothing (but the guys couldnt figure out how to reset it). It is where most people put their turbo timers (bottom left of the steering wheel).
edit: Hairball has issues. PM for details.
Lets get a list then
Unique Autosports = 90ph (tuning 130 p/h)
Croydon Racing Development =
Powerplay = 80ph
BD4's = 80ph
Belgarage = 60ph (has set price for most work)
Also..
does anyone have the phone number for some of these workshops.. Lets get a list going of work shops and hourly rates with phone numbers and suburb. It might save some future questions and help people look around.
Abobob - your right eh.. If a workshop charges half but take 3 times as long you lose out eh
Brendan.. maybe we can get a partnership between No Bullshit imports and Carlos Racing Development.
BEL Garage
Telephone: 02 9763 7022
Fax: 02 9763 7022
Address: 14/378 Paramatta Road,
Homebush,
NSW 2140,
Australia.
www.belgarage.com.au
Full Service  $295
Oil Change (depending on oil used) Labour + Oil Filter $60
Electronic Controller Installation & Set Up - Piggyback ECU  $190
Electronic Controller Installation & Set Up - Replacement ECU  P.O.A.
Electronc Boost Controller Installation & Set Up - Single Turbo  $190
Electronic Boost Controller Installation & Set Up - Twin Turbo  $260
Suspension Installation: Springs $160
Suspension Installation + Setting: Coilovers  $250
Gauge installation: Electronic (A'pexi EL, EL2, Blitz DCII, etc), each  $110
Gauge installation: Mechanical (Splitfire, Autometer, etc),  $160
Exhaust installation - Bolt on only (A'pexi, Trust, Spoon, etc)  $120
ECU / SAFC / VAFC / Piggyback Sub-Computer Tuning:
Road Tune - Preliminary tune, set up, etc  $360
Road Tune - Fine Tune (Per Hour)  $160
Dyno Fine Tuning (Per Hour, excluding dyno hire)  $160
Custom Jobs are chargeable at a pre-fixed hourly rate:  $60
What a shock - Unique Autosports not knowing how something works.
Look out kids, we have another gutless tool who feels obliged to remain anonymous and register a new user name just to have a dig.
GTFO ---->
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
