ULTRA DIMENTIONS
From 7pm - 5am
on 29th Jan 2011
...We will be Bringing you The best in
Hardstyle, Hardtrance, Hardcore, Hard dance, Tech trance, Drum N Bass, Psytrance!
16+
with 18 + Bar Area!!
Pre sale Tickets $30
First Release $35
More on the Door
Avail from Landspeed Records
15th Nov or Street Team Promoters
3 interstate DJ'S:
HSB (SYD)
These Busy boys have been very active in bringing us the best in Hardstyle releasing their Hardstyle boiz vol 2 cd just after Playing Purple stage DEFQON 2010.
DJ THE SAINT (SYD)
Also just coming off the Defqon high, after playing Black stage with Spellbound! The Saint Plays the most insane Hardcore there is around!
DILLYTEK DJ'S
DillytEk were the winners of the 'Rock Da Crowd DJ Comp' in September 2010. The boys have played alongside some of Sydneys finest local talent.
Local DJ's
NOMAD
The finest canberra has to offer! after his UK tour in late 2010, Nomad has produced some awesome HardTrance Tracks Reaching to No.1 including the most recent Do Ya Root in conjunction with Log:one.
NASTY
Also after coming back from her UK Tour late 2010, Nasty is still hitting it hard being a club Sublime resident playing in Syd Almost Every Friday night, you can also catch nasty at Masif, and many other Syd Club events.
SHIFTY BUSINESS
Forming in early 2009 with the idea of bringing mayhem to dancefloors around Canberra and beyond. with playing mash-ups of bass driven hip hop, breaks, electro, DnB and dubstep, with samples old and new, and tunes from the cheesy to the cool,they have proved a hit with the party scene. Also Playing in Canberra's INTHEMIX no.1 Dance festival Foreshore 2010 with headliners tiesto and calvin harris.
Supporting Dj's
LOOSE CANNON
RYZ
SOLSTA
ALAMOUT
CASSANDRA
DJ SOUNDS DIFFERENT
yay four door!!
:) fourdoors
Ahh, welcome. Relocating for work? Public servant?
haha thanks guys, naa im a senior building services designer & cad manager and the ACT office is in need of some leadership so yeah :)
Very very tidy 4 door mate. Let us know once you've settled here and we can bug you to come out on a Friday night.
Yeh i'm very keen to get out and about as i haven't been to Canberra before and don't know anybody or where anything is haha
Might need to go on a bit of a tour show me the hot spots haha
:ninja: fourdoors
:whistling:
Canberra has hot spots? :):P
not far from it lol
I'll also endorse the 4 door comment :)
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
