Bugger.
Depending what you need stuff can be posted, or a delivery can be organized, esp if is regular stuff.
We can look after you <img src="http://www.skylinesaustralia.com/forums/public/style_emoticons/<#EMO_DIR#>/smile.gif" style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />
We'll have to have a chat about it at some stage :huh:
Cos it doesn't get to a post box, means actually gotta buy stamps.
A digital form is easier not to get lost, more secure, quicker to process, and means don't gotta move my lazy arse from my desk chair.
Well actually I don't just work at a desk, but I don't buy stamps, I don't go near a post office/news agency or post box regularly.
Can do things the hard way as necessary, but it is the hard way.
Don't you have a fax? ;)
PLEASE DIG DEEP PEOPLE
Torrential rain hit Queanbeyan in the early hours of Wednesday 8th
December 2010.
Victims were seen wandering around aimlessly, flannies soaked,
woollen trackies sagging, muttering 'Faaackinell'.
Flood waters devastated the area causing approximately $30 worth of
damage, $10 of that at Karabar alone.
Three areas of historic burnt out cars were disturbed. Many locals
were woken well before their Centrelink cheques arrived.
The Queanbeyan Age reported that hundreds of residents were confused
and bewildered and were still trying to come to terms with the fact that
something interesting had happened in Queanbeyan .
One resident - Tracy Maree Sharon Britney Madonna Smith, a
15-year-old Mother of 5 said 'It was such a shock, my little
daughter Chardonnay-Mercedes came running in to my bedroom crying.
My youngest two
Joachim and River slept through it all.'
Apparently, looting, muggings and car crime were unaffected and
carried on as normal with a 95.7 % saturation rate .
The Australian Red Cross has so far managed to ship 4,000 crates of
Bacardi-Breezers to the area to help the stricken locals
particularly those at Jerrabomberra also known as Lower Tralee or East Machonachie.
Rescue workers are still searching through the rubble and have found
large quantities of personal belongings, including Health Care
Cards, Jewellery from Kmart and Bone China from Big W.
HOW CAN YOU HELP?
This appeal is to raise money for food and clothing parcels for
those unfortunate enough to be caught up in this disaster.
Clothing is most sought after - items most needed include:
flannelette Shirts, tight blue jeans or spandex, singlets (blue &
white) white sport
socks, Ugg boots and any other items usually sold in Priceline or
The Reject Shop.
Food parcels may be harder to come by, but are needed all the same.
Required foodstuffs urgently needed include: Microwave meals, Baked
Beans, Ice cream, Chips, Fizzy drinks.
Donations of $15.00 will be taken to buy a packet of winny blue
Supposedly I'm getting a bit of noise from a bearing. It's one of the belt driven things, power steering, A/C or the other one. it's one of the two on the right side of the engine (when facing the engine from the front of the car). Gotta work out which, and how to go about replacing the bearing. Any ideas, suggestions, advice etc?
Edited by J'son
something around there on my car also makes a nasty bearing sound....but mine looks to be more around the cams lol....
Ouch, even less fun.
I've just gotta get a bitta hose, listen and work out which it is..
Was hoping to get some ideas and advice on how to fix etc and what it might cost me (hopefully is something I can do with help, rather than paying trojan etc to do...) and esp before it actually stops working...
hehe nice dress, what a hot look. Matches your mask :cheers:
Your mate thinks a lot of people are assholes lol
He sure does! You know what, the whole night I don't think we brought that line up... which was a good thing cos can you imagine how many f**king times he hears it repeated back at him?? lol
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
