so i'm looking around the room i'm in trying to find something interesting i can post about.
got nothing.
oh yeah! on tonight's episode of At Home with Julia, there's a controversial scene, involving Julia and her husband (whatever his name is) having SEX
and then after sex they drape themselves in the Aussie FLAG!!!!
heard the news on Tripe J today. they said the scene has been raised in parliament and that the Coalition is calliing for an evaluation of ABC funding. I say it's self-promotion. Which is why i'm going to watch that show on tv now!
good night skyliners.
I didn't catch it but saw it on the news briefly and had a laugh. They were talking about how inappropriate it is and wondering if she's getting less respect because she's a woman.
I just think there's a lack of respect because she's an idiot but each to their own!
Can't think why you'd buy a bikini that you can only wear for a couple of hours per year...
Anyway, what do you think of Google + ? I haven't seen it yet. I hope their IM system Is better than fb.
IF they wanna flaunt in a nice bikini, even if only for a couple hours a year, who are we to complain?
I like G+ much more than fb, no apps, no adds.. The chat uses googletalk, to if you have ever used that in your gmail acct, it is the same. And it also keeps chat history (which you can disable), and you can use voice and vid chat through it too.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
