we have a guy is S.A who works on the IT Helpdesk.
He has no arms and picks up the phone with his feet, rests it on his shoulder and then types up the ticket
I expect he uses a headset most of the time but it's amazing just the same
the picture above reminded me of him
Yes i will be Supreme Leader!
Behold my army of invisible robots! ...............
Um hang on..........Behold!...........sht, are there batteries in this remote?
Oh damn, not again..... always loosing the bloody things.... thats the problem with invisible robots.
:blink:
Edited by D.I.Y. Mik
When im dictator everyone will start on a bike, if you survive 2 years you have earned the right to drive.
:laugh:
I feel the same but a in a truck, everyone should experience it, I swear it will make people more observant, the amount of tards I have to deal with everyday is ridiculous. Edited by gtr judd
Get your L's and I'll give you some driving lessons. I got my HR at 19...7 years ago, if I can't teach you a thing or two no one can lol
Have you driven a truck before?
Edited by gtr judd
in NSW, dont need ls to start learning.
so long as you have car licence, and teacher has held truck licence for over 2 years, go for gold.
So I'm putting together a rough plan on what I will need to get my R34 to around a safe 250-280rwkw on a low boost and be a true flex fuel car.
What do you guys think, am I missing any parts or do I have any prices wrong?
I'll be trying to find second hand parts for not so important things like exhaust and intercooler but for the injectors etc I'll be buying brand new this time around.
ECU: Adaptronic = $1100
Turbo: High Flow = $900
Injectors: 1000cc = $650
Coil Pack: Split fires = $450
Fuel Pump: Walbro 400L = $180
Intake Pipe: Metal Pipe = $200
Flex sensor: GM sensor = $300
Intercooler: Return Flow = $500
Suspension: BC BR = $1150
Clutch: KB Clutches = $450
Tune: DVS JEZ = $1700
Rough Total = $7850
Bryce I'm calling you out here because you are going down the same road haha
On the motorsport thread, people have said the BC suspension is cheap, and performs like a cheap one.
Id say they would be fine for the street, but real good stuff is faster on the track.
I guess it depends on what you want to do.
Ps: i went around Wakefield for a couple of laps... so now im a racecar driving expert. :laugh:
Not sure how your ECU works but you might need IAT sensor and MAP sensor. Unless if you want to tune with MAF which is restricted up to 250kw with Z32 ones.
Spark plugs
Dump pipe (JJR $215)
High flow Cat (100CELL has least resistance, could get the venom ones on ebay $250)
Turbo lines too but not essential
Get a boost gauge. oil temp gauge know whats going on with your temps at all time. But may not be necessary because if the adaptronic is like a vipec it will probably go into RnR or do something to stop it going on.
you'll need a MAC boost control solenoid. Get the ECU to control the boost and never worry about changing it.
Depending on the size injectors you get you may need a new fuel rail and pressure regulator but the stock has been proved to work up to +400kws.
Adaptronic does use a map sensor so I can ditch the AFM for this application.
Exhaust will be a JJR but in going to make sure it matches the gasket. I hear they can have some good/poor quality.
As for the BC BR's they will be fine for the street application and occasional track day that I will probably do.
Already also have a greddy profec 2 boost controller which I'll try use depending on what features this adaptronic have. I still have to work out if DVS feels comfortable about tuning with that or if he recommends something different.
Also go the 100cell cat exactly what you recommended a venom one of eBay a few months back;)
Yeah Ohlins and Bilstein ftw if I had money but good luck buying those. Without stressing out your wallet. BCs are pretty good for a budget and pretty comfy for street . People have driven mine and think it's a lot softer than theirs Huon etc are my witnesses.
I'll possibly use the Scotty porn pipe again and buy one of your stock ones Rob to use on the 33. The pipe needs to be modified a little by Scotty though because it doesn't fit up to factory air box and the hoses run too close to the engine.
Fingers crossed the car might come with some secret goodies but who knows
I can provide.
The PORN pipe Scotty made for me does fitup to stock box with the hose ports slightly different to yours.
I'm sure he can tweak it. Or just get a freshy and sell yours to Chris. :thumbsup:
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
