lol turns out I had many over the years....the forums have got bigger but also a bit less close over the years....there used to be lots of those sorts of threads posted
funny to read back thru them actually....especially when I don't go out of my way to promote birthdays!
2004 http://www.skylinesaustralia.com/forums/topic/48257-happy-bday-duncan
2004 Kel threw a surprise 30th with a few SAUers along....including Merli loosing the drink comp with my sis-in-law http://www.skylinesaustralia.com/forums/topic/48290-happy-birthday-drunkan
2005 http://www.skylinesaustralia.com/forums/topic/83217-happy-bday-dundan
2006 http://www.skylinesaustralia.com/forums/topic/129107-happy-birthday
2007 http://www.skylinesaustralia.com/forums/topic/179946-happy-birthday-duncan
2010 http://www.skylinesaustralia.com/forums/topic/331994-happy-birthday-bean-counter
Many lols there.
http://www.fasttech.com/products/2113/10006608/1513500-neosocket-car-energy-save-fuel-economizer
It works by sending good karma down the wires to the engine.
This karma field also transforms e10 into high octane race fuel.
Is anyone else having problems with the site?
After I log in it's still asking me to log in, I have no access to my account details etc and most times I have no 'reply to this topic' field .... This is the first time in 24 hours I've been able to make a post on this site.
I know it's probably been peacefull without me, but just sayin' .. :closedeyes:
.... BTW Mik, gotta love a good Karma stick correctly inserted, who doesn't need a nice karma insertion :yes:
Edited by THE34T
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
