Car Info
1999 Nissan R34 Skyline 'GTS-R'
ARC Super induction Box
Z32 AFM
HKS T04S turbo (small and vintage spec turbo) .63 rear
HKS cast iron low mount manifold
HKS 38mm street spec external gate
HKS dump/front pipe
HKS Super dragger cat back exhaust
Magnaflow stainless steel hi-flow cat
Hybrid HDi GT Spec intercooler and piping
Splitfire coil packs
Bosch 023 fuel pump
Standard injectors
Standard Fuel Pressure Reg
HKS oil cap and HKS radiator cap (yep... made a world of difference)
Nistune ECU
330rwhp or 242rwkw at 17psi
VC Commodore with Neo RB25DET conversion
Plazmaman inlet manifold
ARE custom intercooler
VIPEC Plug n Play Computer
NISMO 740cc injectors
Mercury Motorsport fuel system
Garrett GT4508R Turbo
6Boost manifold
STANDARD ENGINE + ARP HEAD STUDS + NITTO HEAD GASKET
3.5" exhaust by Mercury Motorsport
NPC Twin Plate Clutch
RB25 gearbox
9" Diff etc
POWER: 587rwhp on 25psi (E85)
Car is currently getting a ZEX nos kit fitted and a few other goodies......
Howdy,
Just had my R32 w series II RB25 tuned by Dr Drift.
Mods as follows:
- Nistune & Z32 ECU
- 3'" Exhaust
- Blitz turnflow FMIC
- Pod
- HKS 2530
- Yellow Jacket Coil Packs
- Boost T
- Z32 AFM
Car makes full boost by about ~2,700 RPM and pulls like a train!
Made 218 rwkw on a very conservative tune and only 14 pound
The Doctor does very good work!
Cheers,
Garrett GT3076R with .82a/r internal wastegate, Garrett 1bar big can actuator, Apexi AVC-R + Norgren Pressure relief valve, Trust PE2 Exhaust, GTSLink ECU, Walbro Fuel Pump, Nismo 555cc injectors, complete stock internals/manifolds, Chinese intercooler
301rwkw at 17psi:
Don't have my old dyno sheet handy but...
R34 - RB25DET NEO
Previous:
Custom FMIC
Apexi POD
Profec B
3" Turbo back exhaust
Everything else standard
185kw @ 13.5psi
The car went into the shop yesterday for:
GT3076 IW .82 rear
800cc injectors
Haltech P2000 ECU (Map sensor)
Bosch fuel pump
Hoping for:
250(ish) @ 15psi and
300+ @ 20psi
Will post results and dyno sheets when i get the car back next week.
Hi there from the UK
Here's my first run ever ...
1998 GTSTS2
Standard exhaust
Standard intake system
R34 FMIC
HKS EVC3
Standard Turbo @ 1bar (14 psi) :(
Standard low octane fuel.
300HP 224KW at clutch
248HP 189KW at rear wheels
Edited by Torques
unopened Neo Rb25det
-3076 56t with .64 housing
-highmount AM Performance stainless steampipe manifold with HKS 38mm gate
-Profec Spec B
-600cc injectiors
-fmic
-3.5 inch exh
-Nistune
310 rwkw @17 psi at around 6800 rpm
fullboost by 3500
roughly 480 nm torque at engine (calculated)
got Poncams type B's coming very soon. its a drift car so want more midrange torque. makes plenty peak power. Was thinking i might swap the rear housing to a .82 with pon cams tho... see how i go.
Got the car back yesterday from its final tune..
Stock turbo
Stock AFM
Stock injectors
Splitfire coils
JJR fmic
JJR Split dp
Custom 3' system
boost set at 12psi, tapers off to just over 10 at redline.
222.6rwkw
Tuned by Mark at MRC
Car:R33-1996-manual
Power FC
Frontmount
Greddy style plenum
Podfilter with CAI
3 inch turbo back exhaust
Tomei fuel reg
Apexi-AX53b70 turbo
Stock injectors
Walbro fuel pump
Stock AFM
299.2 rwhp on DynoDynamics at PITS
Had my car dyno'd today at CRD.
Specs:
Rb25det with stock internals
550cc nismo injectors
Bosch 040 fuel pump
Nismo Fuel Pressure Regular
Hybrid? FMIC
Rebuilt VL turbo with Garret 3071 turbine
Greddy Profec B spec 2 boost controller
Old Tuned PFC(In desperate need of a tune
Shitty pod filter
Made 225rwkw on 14psi and 5200n torque.
Cant edit my above post?
Edited by R31Nismoid
'95 SII R33 GTS-T
FMIC
Forward facing plenum
Bosch 044 fuel pump
ITS turbo
External gate
3" Zorst no cat
PFC
740cc injectors
Z32 AFM
Pod filter
BP Ultimate
1 BAR boost
316rwhp @ Allstar Garage
yet to be tuned with new turbs
Garrrett GT30/76
Custom Stainless High mount manifold.
Edited by stR33ter
99 R34 GTT - RB25DET NEO
Custom FMIC
Apexi pod filter
Custom cold air intake / induction
Garrett GT3076 internal gate .82 rear
700cc (ish) high flowed standard injectors
Haltech P2000 ECU (3 bar map sensor)
Bosch fuel pump (?)
Greddy Profec spec B boost controller
Daily driver 'safe tune' @ 18psi = 272.9rwkw
Max power before 6k all the way to redline so definitely has more in it!
Tuned by Simon @ Morpowa.
here's my 89 R32
-flashed over ECU with an Omoni Tune with no restrictors
-1.2 bar
-pump fuel
- RB25 conversion, Apexi 400hp turbo, HKS FMIC, Walbro fuel pump, Splitfire coilpacks, Greddy radiator, shimmed diff.
hit 306rwhp
R33 GTST '96
Stock internal RB25
Nistune
Apexi AX53B70 (P25)
S15 injectors (450cc)
HDi FMIC
Z32 AFM
Full 3" into 2 x 2.5" exhaust
227rwkw
RPM in graph is about 5% too low - full boost at 3500rpm.
3 tunes at increasing boost - still not maxed out (but not too much left, maybe 1psi).
Edited by simpletool
Series 2 R33 96
Mod List are:
Stock RB25DET Engine
Hi Flow Turbo (2860RS) Spec 0.86A/R made by HyperGear ;-)
3" Turbo Back Exhaust.. Punched out Hi-Flow Cat
SplitFires Coilpacks
HKS EVC V Boost Controller
Hybrid FMIC
Cold Air Intake with Partition
Apexi Pod Filter with Hard Intake Pipe
Bosch 910 Fuel Pump
Sard 550cc Injectors
Z32 AFM
Power FC
BP Ultimate 98
Hits 14PSI by 3750rpm
Tuned @ 16PSI by Steve Thomas @ Performance Unlimited WA
Made 318.3RWHP or 238Rwkw on a Roller Dyno
Edited by Black_CSR
1998 Series2 40th Anniversary Skyline
335 RWKW
gt35 .63 rear
Vi pec ECU
725cc Injector Dynamics
22psi
Bp[ultimate
tomei pon cams
will put up new dyno graph once i fit new 272 cams and cam gears and more boost and when i can figure out how to upload pics onto website having troubles im a dummy when it comes to computers.
Edited by UW8NCY
