gr33ddy - Please check your PM's regarding the Oil Cooler I ordered, you have been active since I PM'd you, So I am guessing you missed that you had new PM's.
I need to sort this out ASAP.
Cheers
Chris
  • Replies 141
Hey, I was wondering if the CAI would also fit in an NA R33, looks to me like it would but im not 100% sure, if they do i was also wondering if you had any left or were getting any others in, thanks
  • 1 month later...
Received my R34 Radiator Panel today... can't wait to fit it!
Absolutely awesome delivery time considering distance from SA to NSW; definitely recommended as a seller! :rolleyes:
  • 3 weeks later...
Carbring style Clear top Cold Air Induction Box
for R33 GTS-T, R34 GTT
high quality aluminium made
Bolt on, come with everything u need
$190 posted
Aluminium hood panel
Improve cooling efficiency by forcing the cold air goes to the radiator
finished in silver
R33, S14, S15 -  $105 posted
R34                -  $110 posted
Apexi style cold air induction box
fit S14, S15
$140 posted
interest buyer con contact me via PM :wavey:
P.S.
pls only pm me if u are geniune buyer
negative comment will be given to time waster
Am interested if you have any CAI for a R33 GTST left. Radiator deflector too if have any!:
email: [email protected]
sort out the problem with supplier,
so CAI box and panel are now available again!
got a few CAI box in stock
and still waiting for panel
but won't be long
interest buyer can contact me via PM :D
Edited by Maxx
  • 3 weeks later...
Hi Maxx,
Received the box today (ummm yesterday) all is good
Man that's fast shipping from HK !!
Maxx roxx & his boxx kixx ass. ^_^
Edited by BigDatto
Hi there im interested in one of these CAI Boxes. I dont have an intercooler too improve cooling. With this Box and a Pod has anybody noticed any increase in heat or is it the same as having the stocky box but with cool induction noise. At the moment my car is stocky but all im going to get is a turbo back exhaust and I want the cool sound without going the BOV because of problems associated with them.
it should be better than stock air box (bigger volume, better flow) + with cool induction noise, which design for stock cooler piping.
An improve version for aftermarket cooler piping will be release shortly
Hey Maxx,
CAI Box for the R34: does the entry for the stock snorkel sit at EXACTLY the same place as the stock air box? After my FMIC install, i modified my snorkel to fit around the piping so I only want to go Pod if I can retain that snorkel :blink:
Secondly, these new boxes, do they have 2 holes? One for the snorkel and one for a CAI tube?
I might be interested in a clear top box for R34 :D
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
