Stagea Parts List
Lone
Mate of mine got his S2 back today from the mechnics today (just a standard service - he's too anal to let me do it for him)...I noticed that his mechanic put in set of Plantiums (NGK PFR6A-11) and Ryco Oil Filter Z442. The mechanic told him that he used the same parts from the R34 Skyline
So i'm guessing the Z442 is alright for the S2 stagea (since they share the same NEO motor as the R34)..am I right or am I tripping out?
Yeah I run Z442's if available or z145a's otherwise
i also need to know if the front brake pads on a series 2 Rwd are the same as gtst R33 ?
dont think pads are same as a r33, as no on on hear has been able to match pads up. Can any one confirm?
Im getting a set of Remsa pads for my S2 RWD from a guy on this forum. Will let yas know how they go when i fit em up.
Afternoon,
First time poster. Looking for some help from a fellow 260RS S1 owner regarding rotor and pad replacements.
For most parts so far I've been purchasing parts for the BCNR33 which for motor & electrics have so far been the same. Is this the same for rotors an pads too?
best I;ve come up with so far for rotor sizes are from the link below which had them at: front 324mm, the rears 300mm http://www.skylinesaustralia.com/forums/Wr...60743&st=40
I've seen a group buy and was thinking of purchasing some of these but wanted to check with someone else who's done this already. These appear to be the same size and was thinking going with R33 GTR pads too but wanted to be sure.
4. R32 GTR (late model)/R33 GTR/R34 GTR: F=7701S 324mm RRP $355, R=7702S 300mm RRP $355
http://www.skylinesaustralia.com/forums/Rd...98#entry4760398
Any help is appreciated.
Afternoon,
http://www.skylinesaustralia.com/forums/Rd...98#entry4760398A guy in the stagea parts section has some good rs260 discs 4 sale his name is rsfour.... something ..... save your dollars :banana:
Afternoon,
Brake pads and rotors should indeed be the same as R33 GT-R, as pretty much everything under the body of the Stagea shell (whether it's an s1 or s2 Stagea 260RS) is the same as an R33 GT-R.
  • 1 month later...
CV Joint Boot part numbers as follows...
Hey Guys I have just replaced my front boots with local Kelpro units at $15ea.
Part no':
Inner: CIB-228
Outer: COB-057
Only point I would make is that there is not enough grease supplied for the inner if you ask me, so grab some extra.
For more information, and pictures of the parts themselves, please refer to this post directly here: http://www.skylinesaustralia.com/forums/in...t&p=4849949
tie rod ends - part number - 4852023U26
expect to pay $70-$80 a side..
Ok so here in New Zealand, Nissan is not very friendly...
They first quoted $230 for a tie rod end
Then after using the part number above which is listed as a "Socket kit" (they said) it would cost $150+GST
Then calling aftermarket parts place "Partmaster" they said $63 for R34 GTR tie rod end which matches part number:
48520-23U25
Note after searching all available Stagea information, I found various references to the part number ending in 26
and most of the threads don't have the final information of which part fit... :)
but this one:
http://www.skylinesaustralia.com/forums/St...39#entry4248839
Seems to indicate that 48520-23U25 would probably fit...
so for a $63 risk I'll probably order one and see if it fits...
Any advice?
my car:
1996 Nissan Stagea RS FOUR V
Chassis: WGNC34-004669
Model: TGKNREAC34UDAAB-CA
Engine: RB25DET 2498
48520-23U25
and most of the threads don't have the final information of which part fit... :P
but this one:
Any advice?
my car:
The confirmed part number for a 96 Nissan Stagea RS4 front tie rod end is 40520-23U20. AKA socket kit. I had to jump over this hurdle a little while ago myself.
I can get you a brand new one for AU$150 shipped to NZ direct from Nissan Japan. PM me if you are keen :P
Edited by performance-wise
I can get you a brand new one for AU$150 shipped to NZ direct from Nissan Japan. PM me if you are keen :)
Hmm I PMed Chook and also obtained a copy of Nissan's FAST software... (albeit from 2001)... however I believe that both your part number from Nissan, and the 48520-23U25 part would probably fit and be the correct part... I have discovered that Nissan has a complex "Super-cession" system whereby new matching parts get new numbers...
In fact a major part of the FAST software is dedicated to "Alternate part lookups"... however the aftermarket parts market often sticks to the older part numbers, so going to my local Partmaster to get a 3rd-party version their book lines up with the old part number...
Cheers for all the help,
Gaspard
Hi all, this reply-post is an offer:
I have a copy of Nissan FAST working here so if you give me your VIN or Chassis/Model/Year then I can lookup genuine parts and see what else used those parts...
So the offer is, please post your questions here. then I can look it up and repost here... which means the parts thread gets some part numbers.
Limitations: only have up to 2001 version so no newer cars are covered... However, Series 1 and 2 Stagea are covered, and R32, R33, R34 are in there so yeah.
easiest to get exact results with the VIN Number in form (for example) WGNC34-004669 (this is my one)
This gives me trim level, engine type, even body colour ... Code... lol
The program has a Parts Master module which if you enter a part number will show what cars that part was used on... I find handy for cross referencing to more common Nissans which are in the book at the local car part place.
oh, PS if you give the NZ Plate number (for NZ users only) then I can use CarJam and lookup the VIN (usually)... so yeah.
Cheers
  • 2 months later...
Hi guys,
I'm after a part number for a 2003 NM35 nissan stagea
Air Filter no.
I'm just wondering which one of these fits my car
http://www.nengun.com/nismo/s-tune-sports-air-filter
cheers
OEM air filter part number is AY120-NS001
Same as C34, Z33, V35, R34, S15, J31 (Maxima) etc
Nice, easy replacement
  • 1 month later...
Just found this on the Penrite site:
Make NISSAN (JAP)
Model Skyline GT-R
Engine P
Year 1995 - 1998
Application Recommendation Capacity (ltr)
Engine (P) (RB26DETT)
First Choice HPR 10 - 4.2L
May also Use HPR 15
Manual Transmission Transaxle 75 - 4.1L
Automatic Transmission -
Differential First Choice Hypoid 80W-90 - 1.3L
May also Use Transaxle 75
Coolant -
Front Differential First Choice Hypoid 80W-90 - 1.0L
Transfer Box ATF DX-II - 1.6L
Hello All
I have purchased a new tail shaft centre bearing for my 2002 M35 unfortunatly the supplied part does not fit, the ID is too small. The dealer is no help saying that the part is for my car or I have a different tailshaft. The supplied box shows part No C7521-OV526 it looks like it has been returned before I was given it. Any help on what might be the correct part number or an equivilant Australian delivered car that similar bearing may come from.
Thanks
Muz
    • WELL IF ANYONE HAVE HIS PERSONAL CONTACT DETALS PLESE PM MEWell does any one have his contact details othe than in SAU? IF ANYONE DOES HAVE HIS CONT
    • I dm’d him about 6yrs ago and he still hasn’t opened/replied lol
    • G30-770. So long as you're talking engine horsepower, and not some bullshit wheel/axle/mystery horsepower.
    • It's a lottery, no one is going to be able to predict how much HP YOUR engine is going to handle as history has a huge part to play.    As examples though. I have one rb26 on 630rwhp, running 16 years now at that level, track use, only a couple of times a year.  Another 790rwhp, about 2 years now, driven every weekend.    If i was to give you a "safe" number I would say 450rwhp on 98 and 550-600 on e85.  Seen plenty of motors pop with less though too
    • Fair play on the 120k, sorry just live in nanny Aus.  High rpm on cruise would kill me too.    On the gears, its not just first, so beside the fact I really enjoy that nice punch you get when you accel in first. 2nd is all messed up in the gearsets too. Most people I know with gearsets(even sequentials) have to drop into 1st for tarmac rally slower corners as second gear is too low in rpm, its painful. Translate to the street, I am using a 2.3 gear out of a low speed turn, gearset you got a 1.7 second. I can tell you now between my two cars which one is a LOT more fun.    On a track its a different story, once the car is moving the gearset ratios are supreme, 1st gets you going on a big rpm launch, then 2nd is no issue for the corner speed on most tracks.    Yer the price sucks  , old enough to remember these selling for $1500usd here in Aus.
