I'm planning to upgrade my injectors soonish so I've started to look around now. My current injectors are a little sus, as my fuel tank was rusted to the shithouse and some of that red stuff must have gotten through the fuel filter. Starting is difficult and fuel economy around 14L / 100km.
Getting a nistune in a couple of weeks, and apart from a 3" hiflow exhaust my HCR32 is completly stock, so I was thinking a more modern type of injector with improved atomisation would be better for response and economy, does anyone have opinions on how these ASNU / Bosch injectors compare to the Nismo ones?
http://www.asnuperformance.com.au/
  • Replies 153
Yep, not sure why but GTR injectors just seem to give poor economy from the tuner I spoke to, he said they also commonly leak through the injector body, I know mine did both of these things but I can't comment on the truth of how common it is or why.
  • 2 months later...
Sorry for thread jacking but any opinions on the ASNU1000cc injectors heard they can improve economy.
http://www.asnuperformance.com.au/gallery/High%2BPerformance%2BInjectors/ansu-performance-1000cc-injector/110282
  • 9 months later...
Old thread I know but I have a quick question, Instead of wiring in 6 resistors close to the injector can you not just wire in 1 resistor on the 12v feed before it splits in to 3 then the other 3? Just 2 conections to make instead of 12 or is there something im missing?
As it is batch fire 3 injectors fire at once, so if you multiply the resistance by 3 and use a single resistor it would work imo.
Sorry my bad divide it by 3 as V = I*R so V/I = R so if you have 3x as much current you require 3x less resistance
12/1.2 amps = 10 ohms, as 3 injectors will fire at once you have 3x as much current so 12/3.6 = 3.33 ohms
Obviously the battery is closer to 13v and hence lower amps but the theory is the same however you probably can't buy a 3.33 ohm resistor, to get an equivalent resistance of 3.33 ohms you could run 3x10 ohm resistors in parallel bunched together, be easier to solder in one big lump than putting one on each injector.
Up to you I guess.
  • 2 months later...
What is the nicest way to wire the resistor to the 3 injectors in the sub harness so you can still unplug it from the main harness when pulling the motor out?
I understand that for one injector you could use the existing wiring, but what about the other 2 in the sub harness.
Hope that makes sense
  • 8 months later...
no nistune/ ecu talk... cant even get the ecu in diagnostics mode :dry:
engine does crank, did not start when pump was hard wired, injectors are getting power
am going to install stock injectors again and redo wiring back, isnt the daily so not a big waste
  • 4 years later...
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
