  • 7 months later...
Im sorry to be digging up an old post, but I have been trying to find some information on the EL hand controllers and in particular the issue of the screen going dim and becoming un readable.
My car is running an R32 GTR Power FC and 4 years ago I swapped my original hand controller for a new EL hand controller as it was way easier to read while driving.
I have noticed the last time I used the car the readout was very dim, even with brightness at 100% and I just went to start it and give it a run and the display is now almost unreadable, especially in the sun. My car gets stuff all use, in the 4 years its probably had no more than 20 drives, so fair to say, Im very dissapointed with the lifespan of the display!
Has anyone had this issue and how did you fix it?
Thanks and sory again for diging up an old thread.
Are you handy on the solder iron? I can point you in the direction of replacing the screen yourself. I've done this quite a few times for myself and a couple mates. (There was a light reflection when photos were taken)
  • 5 months later...
On 13/11/2019 at 10:45 AM, paulr33 said:
updated the first post also, happy reading from 2012....
Hello Paul,
I thought that may be you can help me. When I tune jzx90 toyota chaser with power fc I have an interesting issue which I couldn’t solve. Issue is when I plug in tps sensor socket and make wide open throttle car bogs (like boost cut but off course its not a boost cut because no boost yet.) and when I plug off tps socket engine check light comes on but engine revs and boost comes on without any bog. On power fc commander vta1 is 0.4v at idle and at wot its around 4.1v.  If you can advise some solutions to me I will be happy, may be I did something wrong but tps looks fine because voltage increase when throttle opened and check engine light goes of when I plug in the tps socket. Thank you in advance.
  • 3 months later...
It's probably worth a separate thread, but I'd say that is very interesting. Lots of people running PFC, since nothing has changed about the fact they are a cheap and easy way to tune an RB for 90% of uses. Plus I think they will start to be desirable for the "keep the purity" crowd who want period modifications.
  • 3 years later...
They definately are coming back around, so many GTRs coming through again with them.
  • Like 1
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
