Hi All,
I have been trying to make some improvements to the R32 GT-R Workshop Manual PDF that's floating around as I find its pretty unusable in digital form.
Anyway, after a couple of hours work I give you the improved workshop manual with rather complete bookmarks (make sure you open the bookmark tab in Acrobat) :D
Download the Zipped PDF (~21Mb)
Mirror by Amaru: http://gtr.infinite.net.au/lw_gtr_32_servi...vice_manual.zip
Not sure how long I can keep it available as it will depend on bandwidth. If others want to host mirrors, that would be great.
Let me know if you find any mistakes and I will try and fix them ASAP and reupload.
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/68078-improved-r32-gt-r-workshop-manual/
  • Replies 42
is there any software around to traslate the picture to text? like you can do if you scan a document.
The problem is that, unfortunately, the manual was scanned as a series of images rather than using Optical Character Recognition (OCR) which would have made all the text portions appear as just that, text. As a side bonus, that would mean the text is searchable, selectable, copyable, etc etc.
I just tested exporting the PDF to image and running it through some OCR software. It seems to work OK, but will take a considerable amount of time to process. I will have a fiddle and see what I can do.
Richiarid :D No problems.
Lucien.
Hi Guys,
Your all very welcome. I hope you find it useful. Its nice to give something back (that people appreciate :D) to the community that's given me so much :grouphug:
Anyhoo, after trying to latest version of OmniPage (and OCR package) it seems it can import directly from PDF. I have experimented with it a little and it will still be quite an effort to swap it over from images to text, but give me a little time and I will see what I can do.
Lucien.
nice job matey....... it has help me out a hell of alot with my rb conversion in my 66 gt........ much appreciated .... good to see some decent people out there!
cheers.... :D
Ok,
I have spent the better part of the day trying to process the workshop manual with OmniPage. I have managed to get 100 pages done (so approximately 1/8th of the manual):
I would be interested to see if people think having text and images (rather than just a series of images) is useful -- ie. the text is now fully searchable. If you have a minute, feel free to download the 100 page "sample" and have a play with it. If people think its worthwhile, I will keep going and try and do the lot.
Sample is here (~9.5Mb): http://ugbox.net/~lance/OCAU/lw/R32_WM_Rev2_Test.zip
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
