I need new tyres for my R33 GTS-4 (non-turbo 4wd).
Current tyres are 225/50/16 Sava Intensa, which seem to give adequate traction for my car.
I can get the same ones (Sava) for around $180each?
Cheaper Nankangs for around $120each
Or something like Goodyear Eagle F1s for $210each
They're the 3 I was told about today anyway.
Any suggestions?
Car is just a daily driver obviously and I want something that has decent grip in the wet too. Current tyres aren't too bad in the wet, it will only slide in the rain if you make it (obviously 4wd makes it harder).
I get $10 off a tyre, so F1s would be $800 fitted and balanced, which is probably the most I would want to spend.
I don't really want to get a cheaper tyre than my current Sava's so probably wont get the Nankangs but might consider the F1s if they are good?
Yeah thats definitely them. They cost good money as well.
I'd have to go with Duncan on the SP-9000's. I also found them an excellent road tyre, and would definatly use them again.
You must have got a bad tyre, incorrect suspension setup or tyre pressures to be unhappy with these.
Hi Scotsman, my wheel alignment was done at East Coast Suspension which is supposed to be good. I have since found out though that I was not entirely fair on the sp9000's as I have never really liked the front end of my car and that was due to the front spring rates not being hard enough, the standard (too hard) bump stops and the whiteline swaybars being incorrectly set. I have had the bars fixed and it has made a big difference but it is bottoming out in the front all the time (only lowered 1 inch). Its not really obvious but you can feel it and it makes the car very nervous on imperfect surfaces (read: sydney roads).
I just need to get the custom springs made up and I have a funny feeling my opinion of the 9000's will change.
Hi all,
Just purchased an r34 GTT sedan, currently on bridgestone import tyres and handles great! Unfortunately I need to buy new tyres and am overwhelmed by the options including width, price etc.
Given that most half decent 225,45,17's start at $225+
Could someone provide some feedback on width?
I am running stock rims and unsure if I would get improved ride/handling by running wider rears? eg. 235 fronts and 245 rears?
Thanks...
I currently have Michelen Primacy, which are top of the range Michellen tyres.. Even tho i have bought second hand tyres, the grip on them is just to good.. They really stick onto the road.. even tho with 50% thread left, im really happy..
Got the primacy on z32 rims, with 215s/55/16s..
Worth checking out the primacy range.. But $$$$..
im digging into my pocket again for two tyre's
i bought some wide ovals for the front and i am happy with them but i cant get over the feel of my car with toyo tpg's on it's so gripy an with lots of rain coming down i dont even worry about slideing. @ $205 for 17's its a bit pricey the toyo 16's only cost me $165 its a big jump in price for one inch bigger rim delemas delemas
Nankang... they've done about 5,000kms, a track day of... "drift" (not overly, more grip sessions, but all 20min sessions and they still look and drive fine) have good grip in wet, and are... relative in the dry. HOWEVER, IMO all problems aside with every tyre I've ever tried is to do with varying power levels, driving conditions and how much abuse they sustain, also, suspension/braking and so on... as you can't really do a back to back test unless taking them to the track of a stack of lap and then comparing etc... SO there are a lot of variables when trying to compare tyres I think.
Cheers
Grant.
Just wanted to put a word in for the Bridgestone S-03s. These have done over 10,000 km on my car now and I just took them to a track day at Queensland Raceway where they did more than 30 laps (5 lap stints).
They're wearing ok (-1.5deg camber on the rear) and probably have about 5000km left in them, maybe more if I rotate them across the rear. They handled the track day well and didn't crap themselves though the front left looks a lot more average now than it did a week ago. :lol:
By lap 5 of each stint they were feeling a bit soggy but that's to be expected with a road tyre I guess.
I cannot say enough for these tyres in the dry, they are just so predictable and grippy. They're not so hot in the wet (sideways in 4th gear on the freeway, anyone?) but I am running about 240-ish rwkw with a 255mm width on the rear so they have their work cut out.
So yes they were freaking expensive but I'm not feeling overly ripped off. Next time I will probably try the Toyo T1Rs or those Revspec things (if I can find them) or maybe the Hankooks, but only if they're significantly cheaper than another set of S-03s. :(
Has anyone tried the S-03 vs something else?
hmm i thought primacy range were top of the list.. they are like 395bucks each tyre.. isnt that expensive..
I also have piolts hx on the fronts.. They are alright tyres as well, but they are getting really old, you can see marks on the tyres..
How much does the sport and the preceda cost?? Do they have more grip than primacy tyres??
nope just have a look on the michelin web site if u want more details. they are expensive but pilot sports are even more expensive :P and yes sports would have more grip for sure plus other sporty qualities.
Whoooohoooo :D
Just got my new T1R's on. I got 235/45ZR17 all round but found out i could have gotten 255 on the rear. The d@ckheads who serviced the car previously (before i owned it) had rotated the tyres. They put the 17x8 on the front and the 17x7 on the rear, thought it felt like crap.
Feels good so far but havent really tested them :D
The guy also mentioned that i should get a camber kit as one side is 1.3 and the other 2.
btw - Paying between 250-400 per tyres isn't exp to me, anything over that is though. Heard somone paid approx $800 per corner for pirelli 265/30's on 18 or 19 inch rims, no thats exp
:laugh: and yes sports would have more grip for sure plus other sporty qualities.
FUNNY - how so may I ask?? LOL
Just a point, I ran Pilot Sport for $220 (rear wheel, 17inch) on my Fireblade, and now run Pilot Power ($280). The Power is far superior to the Sport, and the Sport is a model that is around 3yrs old in the motorcycle industry... so maybe the Sport in car tyres is the older model, with Primecy being the latest model?
How so? well what i mean by sporty qualities is that they will last longer before turning to mush, grip more, and have stiffer sidewalls that improves grip and steering feel etc etc.
for cars its different, sport is the better one just look at the michelin website if u want to see for yourself :)
About to gat a set of 4 tyres, 235/45/17 for a budget of exactly $200 per corner.
Probably going to go the Hankook 104's for that price.... but what else compares to the 104's in regards to wet weather grip & matching price?
Cheers! :sorcerer:
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
