Ok.. Just wondering if people use either of these tyres on their dailys. I just wana eliminate 2nd gear wheelspin (and some of 1st), and I'm a happy fella. Dont care which tyre, hopefully they last more that 10-15,000kms too.
  • 3 weeks later...
KU36 going on the car today. It's no Rs3 but I couldn't turn down free replacement tyres.
Also if you're ever considering Goodyear Eagle F1 Asymmetric 2, don't. I have had two sets and both developed cracks in inner sidewalls in under 2 years and 20,000 kms.
tyres tyres...had Federal RSR 255/40/17 on the rear but 9000's ks and down to treadwear indicator...annoying thing is, HEAPS of trad left in side blocks, they're built very well for that. Looking at either Potenza Adrenalin RE003 or Dunlop Direzza DZ102, in a 235/45/17. Apparently that Dunlop tyre suits well in warm weather, might do well in the permanent summer of Qld?
  • Like 1
Im hearing a lot of good things about the AD08R. It is making quite intrigued to give it a go. But holy jesus its about $1800 for a set in my size.
Im sick of my RSR's and am tossing up between dunlop z2's, advans or a bridgestone potenza...
anyone tried any of these on a track?
I have the AD08Rs 265 35 18, they seem to hold power very well and unless you are trying really hard with AWD, no spin, chirp and off you go.
I got the Potenza RE003s around two months ago and they're fantastic, in the dry and in the rain. But then again the old set I had were so bad and worn I couldn't even make it up the driveway on a rainy day, so I'm experiencing a massive improvement with the Potenzas. If you're already used to having good tyres the Potenzas might not seem like much.
  • 4 weeks later...
so I got the RE003's....on for a week and not wowed by them, they're ok but seems sidewall is too soft, leaving them lacking in directional stability on the front when cornering hard. Will put a few more psi in them and see how that goes.
Had also used Nitto Invo's - bloody excellent, soooo much grip in the wet, I would have to ride the brakes HARD to get them to lock. Great in the dry too and very stable in cornering; got about 9000k's to them with about 25% tread left, at which point they had noticeably lost grip but still quite predictable, even though slidey.
Also used Michelin Pilot sport 3's, found them similar to the Invo's but just not quite as good IMO.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
