1 hour ago, admS15 said:
Why not price up some Ad08R. There is a buy 3 get 1 free offer running atm and Bob Jane does some pretty sharp pricing. I bought a set in 265/35/18 and they where cheaper than RS3 and not too much more than RSRR in the same size. Food for thought.
oh sweet ! thanks, i didnt even consider them, as usually advan gear is hella expensive.
how do they go in the wet ? and track?
Fantastic on track as everyone keeps saying. On the street in wet weather they are quite good but it's not like I try to go hard in the wet on the street. In my experience so far there hasn't been any unwanted wheelspin. They feel as good and possibly better than rsr and Achilles 123s in the wet and much better dry. When I called around for quotes, surprisingly bob Jane did the best pricing by far.
oh thats great to hear ! thanks for that ! i must admit i have never reallly paid attention to advans purely due to cost, and knowing they are usually awesome but thats about it.
Thanks for the help mate.
  • Like 1
would you believe there is NONE IN AUSTRALIA apparantley !!!!!!!! bloody bob jane.
Just ring around, someone may have stock somewhere. Even if they don't have stock, I'd be asking to buy now to lock in the buy 3 get 4 deal, then ask them to just fit them later once they're available (assuming you can wait).
Also, just call around to any other shop you can think of. When I put AD08's on my Golf R, I literally called a dozen different places. Prices varied from $460/tyre down to $360/tyre (235/35/19).
My honest opinion, don't let the price scare you. For daily, spirited twisty roads, or full track days, nothing beats the AD08's. My last set even lasted 35,000kms - without any rotations either!
I have no idea where you are located, but if you're in Melbourne, try Associated Tyre Services in Cheltenham. They deal with Yokohama a lot, so get much better pricing that other shops.
3 hours ago, admS15 said:
well unfortunately i need tires this week. so RS-3 are out of stock, ado8r are months away.
so Federal RS-RR are the only ones i can get my hands on. i loved the RSR so these should be better than the predecessor, but noiser.
Thanks guys, might give the Bridgestone 003s a try, our very own Nismoid has reviewed them here and recons they give the Michelin PS3s a good run for their money and they're a bit cheaper too.
Just done 10k on Direzza DZ102 on our daily. Plenty of life left, can do $40k+.. Quiet tyre
Quite impressed with them.  Usually $180-200 for an 18 inch tyre we got ours for $144 each. Great tyre, can easily compete with $250 tyres
Dry 8/10
wet n/a
value for money 10/10 for $144.  9/10 for $200.
Would buy again if they had correct sizes. Sizes are a bit limited....
that is the most biased review ever. Paid-to-plug I think.
read recent posts, I didn't rate the RE003's. Go the invo's instead.
  • Like 3
Thanks for feedback, I've only book in so can still change my mind, will get some quotes for the Nitto Invos and PS3s
This is my daily and will never see a race track, so my priorities are wet grip and noise.
I've got PS3s on my Stagea and love them in both wet and dry, and just recently put a set of RE003s on my mum's Golf and found them great too in the dry (haven't had a chance to try wet grip), if a little noisy. Nothing turning up the radio won't sort out - the noise is far from excessive.
Dry 8/10
wet n/a
I have these on my daily as well. For the price they are a really good tyre, Good dry grip, very good in the wet. No road noise and zero tramlining. My only criticism would be the sidewalls do seem a little soft and will flex a little more than I would like when pushed hard into a corner. But otherwise a good value underrated tyre
  • Like 1
On 01/09/2016 at 11:07 AM, niZmO_Man said:
It'll be fine for a street car (from the reports I've read). Although, Nitto Invo is equivalent and quieter apparently.
On 01/09/2016 at 11:14 AM, Hadouken said:
I do rate the invos. Wet grip is very good.
Unfortunately the Nitto Invo are not available in my size, 205.55.16 any other suggestions?
yeh, go another size. Why are you only using 205's on a skytwizzline anyway?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
