You'd have to convince the person who owns the name to give it up. As they've been inactive for over a year that might not be easy but we can't just take it because they haven't use it in a while :cheers:
haha
dammit
ok
can you change it to Mr. Oizo
post what you'd like your new username to be and I'll change em for you. Only an admin (me Duncan, PranK and a few others) can change usernames. Alternatively use the new troubleshooting system to submit a support ticket and one of us will sort it out.
Can you change my username from falcs81 to RBJ3T
How do we know when it is changed? lol probably when I can't log in on my old username.
Cheers Funky
I am very new here lol. But disliking my name as it was the first thing i thought of when i first signed up a while ago.
Ill take anything as long as its got Mattyk, MattK123, etc etc. Cheers :ermm:
Hi, can you please change my username to 'r33skylinegtst'? Cheers!
can mine be changed to 'eMsta'
I would also like a change please. I am datt0man everywhere else, so to save confusion (for me that is) can I have that? thats with a number 0 not the letter o. thanks.
Hi, Could you please change my username to *Miss*
Ill take anything as long as its got Mattyk, MattK123, etc etc. Cheers :D
got plates an want name to match - can i have my name changed to TAKUSHI
All done!
You'll get an email when your name is changed, to the address in your profile.
Matt, you got your second choice as we already have a MattyK :)
Can I please have my username changed to "typevu".
:D
Hi,
Can you please change mine to $nightcrawler
Thanks!
Both done :/
Can i please get a change to Lil_Bobby_260
New car!!! cheers Revhead.
You certainly can - and congrats on the new Stag!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
