  • Replies 393
FYI: My car is fixed. Wow looks like this thread is great... Too bad I missed out! Next time!
Oh I paid $15 and didnt go, do I get it back? Or get a laynard?  hehe... well just donate the $10 or $15 to SAU :D
We can send you one.
I must say that your car looked even better on the road....well done and congrats!
The R32 is non too shabby either, as I said prior, there is nothing like a track car that can hold their own with a show car!
thanks for the great weekend away guys! coming up from canberra, the three of us (R31DET, LTSjayce and me) decided to stay the night there.
the quality of cars was great and winners were well chosen. i didnt win an award (i never expected too), however i did win the raffle 1st prize, so i cant complain. count on us coming back next year with a couple more.
cheers
Merli or any of the organisers,
I have just spent 10 min on yahoo and google and could not find any ref to the Driver training day with Aaron Mcgill. Can you send me a contact number I to call and discuss?
Paul, try http://www.auto-motion.com.au/ :D
edit: just realised there is nothing there. his other site is http://www.aaronmcgillmotorsport.com/ nothing there on driver training, but aaron runs a top day. great guy and driver. i believe you can email at [email protected]
I just spoke to them. Im booked in, at Oran Park GP 22nd Nov 05 unless they can grab a cancelled date at the creek.
Kabab with cheese, the Aaron Phase 3 day sounds the same as a UAS day, no real formal instruction, but instructors on hand if needed.
Guest DIRTgarage
Stacey is keen to add a black R34 vpec II to the garage. We are ordering ours next month....if it looks as tough as yours i wont know which one to drive.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
