My 99 Stagea S2 rear rotors one side is crack! Need change, but i couldn't find any rear rotors for sale for my S2 stagea, they mostly sell rear rotors for M35 or just front rotors only, anyone please tell me where i can buy? Even second also ok f ok for me, i am from Melbourne. THx guys, pls.
I just had the same prob with an S1. Finally got a set from ebay.
Try DBA site or go to Supercheap with Vin No.
  • 1 month later...
G'day, ok getting pretty tired of stock brakes with Bendix pads same as X-trail.
Looking at some V35 Brembos from a wrecker.
How do I tell if the rotors have any life left in them ?
Might get ripped off.
cheers
cheers
Nominal rotor thickness is 30mm; lower limit after machining is probably 28mm.
You'll need pair of vernier calipers to measure accurately.
Used V35 Brembos
Is $1400 too much for a full set ?
Near new slotted discs.
cheers
For a complete set it's probably about as good as you'll do; I've seen tards asking $1k for just the fronts, with worn out rotors.
  • 3 weeks later...
  • 1 month later...
Yes this thread is way too long, with 90% unanswered questions and lots of facts without type of Stagea there for etc. I guess a majority of people no longer have a mighty Stagea in their garage.
I have a Stagea S2 1999 model, I've done about 200K probably on original rotors. I think im overdue for a new rotor and pad combo.
I've changed the pads twice since i've owned it.
Front pads: Once with GSL Rallysport GSL009 HP-X and once with Remsa 0852 14 (Renault Koleos 06.08, Nissan Murano).
Rear pads: Once with GSL Rallysport QDB1399 HP-X and once with Bendix DB1399GCT.
If I can find some rotors i'll probably go to GSL Rallysport again.
Otherwise I might try the upgrade option. I have some R32 GTR calipers and 4 piston alloy Calipers (I think from Z32 turbo). I also have R34 GTT rims on it so probably not a bad option.
On Ebay you can get Rotor and pad packages for Stagea 1996-2001. But I think this is a typo and only for series 1 (1996-1998).
  • Like 1
Just wondering if Auto/Manual or RWD/AWD makes a difference at all.
Just fitted new slotted and dimpled rotors with QFM HPX pads
Also had the Brembos fully serviced. Awesome braking.
I have a slight whirring sound and pedal feel when they are hot.
Hoping this is just still symptoms of bedding in, and not something that comes with dimpled rotors...
Anyone noticed the same ?
Funny I did research before I bought them.
Nothing about noise/feel just positives on cooler rotors and pads.
My stockers were slotted fronts and did the same thing, I thought is was shit pads.
I didn't buy them to look cool, just went on performance forums opinions.
Have you ever heard a girl say "mmmmm, slotted rotors... I think I wanna sleep with you."
I haven't..
So you did research and it said that slots and dimples are better?
That is a shame.
search ferrari brakes on google and try and find one pic of a smooth rotor
here's one chick that does dig cross drilled anyway
Edited by conan7772
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
