18x9.5+22 255/40 A050s all round.
Would not recommend without serious camber on the fronts, or pumping them hard. Chewed the guard hard on tight corners. Rears were fine.
Are you sure that's 9.5? I know semis are usually a tad wider but that looks more like 255s on 9"
I am looking at this myself as I was wondering if I can get close with 9.5 +27. I have -2.2deg camber at the front, and happy to roll and maybe even flare guards if the price is right to get it done.
As you have it, how close is it from being feasible?
Yeah they are quite large. I think 265 are supposed to sit sort of flush on a 9.5, but mine are still quite bulged.
Update on my fitment. I pumped/flared my front guards and had minimal scraping issues. Running maybe -2/-2.5 deg camber I should have no clearance issues with the current height.
any thoughts on 17x10+38 in the front?
I've already got this in the rear and it sits super flush with 265s and would ideally like a square setup so is this going to work?
obviously going to need some fender work but am i going to smash my struts?
cheers
39 minutes ago, niZmO_Man said:
Pretty sure that'll hit. You can measure it though :P.
not for another couple of weeks, i'm away for work and was hoping to put an order in so i can have them for when i get home  :banana:
looks like i'll just have to chuck the rears on the front and see how she goes, fingers are crossed
cheers
I don't think they will, I test fitted my old rears - 9.5+38 on the front of my 34 with a 15mm spacer and there was about 10mm clearance at most
10" and +38 would be up against the suspension I think
Currently using 9.5 +26 and have about 10mm clearance
that sucks.. not giving me much hope but i'll still give it a crack once i get home.
i found this:
http://honda-tech.com/forums/vehicles-sale-42/f-s-2001-nissan-skyline-gt-t-sedan-3175277/
rpf1's only come in +18 or +38 in 17x10 and that to me doesn't look like a +18.. it sits how my +38's do on the rear. i do however have a coupe not a sedan but surely the guards aren't 20mm wider on the sedans?!
also:
http://forum.jdmstyletuning.com/showthread.php?7362-The-Skyline-Picture-Thread-(non-GTR)/page91
about half way down the page there is the 34 on 370z wheels. it looks as if he is running a square set up of the rear wheels and they are 19x10+30.
Edited by solldogg
i found this:
also:
I can't see the first link being 10" wide all round at +18 offset, they seem to sit within the guard line!
I have a sedan, and the front guards are the same as the coupe, and the rears fit much the same as the front, maybe 10-15mm more clearance
The 370z rims seem to have a fair bit of camber to squeeze them under
Here's how mine fit at 18x9.5 +26, 245's on them. It's as wide as I'm willing to go as its a daily that I like to drive without smashing rims into guards etc
I couldn't get much more under the front with normal camber settings 577cfd20018b1_ImageUploadedBySAUCommunit
577cfe269436b_ImageUploadedBySAUCommunit577cfe37a0802_ImageUploadedBySAUCommunit
  • Like 2
To add to the above post, I have 18x9.5 +27 all round, with 265/35/R18 AD08R (supposedly a little phatter than most) on all 4's. I have -2.2deg of camber at the front and about 1.5 on the rear.
The guards DO need to be rolled/pulled a little to get these to fit. After driving around for a week without this being done there were many bad sounds and long strings of rubber peeling off tyres and such. I don't think this would have been a problem if running 245's like above poster ^----
The rear does tuck in under compression (I have a large amount of squat in the rear of my car when on the fun pedal)
  • Like 2
  • 5 weeks later...
Lads,
I'm sure this has been answered previously but I can't seem to find the exact reply to the exact sizes I'm looking at.
Would i have problems running;
Concept Concave rims at
- 18x10 +20 all round
- 235/40 or 245/40 tyres
- Rolled front and rear guards
If not what would you guys recommend running? They stock 18x9 +20 also, would this be more appropriate for the front and 10" +20 for the rear?
I'm after an aggressive look that wont poke too much and id rather not run staggered but i also don't want to run Mexican spec either!
Sorry for the ridiculously pedantic requests but i can't seem to get the right answer and I'm stuck!
Help would be greatly appreciated!
Cheers
6 hours ago, Snipes said:
Lads,
Cheers
If it's for a 32 GTR, 10+20 will be perfect and can run a decent tyre size like 265
Hopefully someone here is an expert on wheels and offsets and can provide me some "real world experience and advice"
I am interested in acquiring a set of Rota RKR Wheels.
PCD 5x114.3 in 17 inch.
Issue I have is that I currently have a set of wheels that have printed the following 17x10 with ET 15 (doesnt state whether its a + or - ET 15) which fit like a glove! But are shit wheels
I am trying to figure out what my options are in relation to the Rota RKR offsets and what will work.
17x8.5 -10 or 17x9.5 -20
Hope someone can lend some advice on this
  • Like 1
http://www.willtheyfit.com/
I can't seem to work out if a set of Rays LMGT2 17x9+16 with 255/40/17s  will fit on my R32GTR.
I've searched but can't find anything.
Has anyone fitted Rays LMGT2 17x9+16 on a R32GTR without rolling the guards? I'd like to avoid rolling them.
Any help will be appreciated
Andy
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
