not so bad, you can now buy something that works. HUMM, maybe i should do thesame. LOL.
On another note, i scorred all the gaskets and studs and bits and pices needed for the exhaust manifold repair for $154 all up. YEEHHHAAAA.
Looks like i have sold my snotter :(
damn :ermm::ban:
you can both buy my 33 :O , hasnt missed a beat :w00t:
:O you shouldn't even have to ask what the plan is!!!
damn :ban::(
you can both buy my 33 :ermm: , hasnt missed a beat :w00t:
Still got the turbo for sale though Toff :P
Id love to buy your 33 but i just need some wheels to get around the net few weeks as it is without being fancy!!!
wogs....what was your torque reading on the 25?
at 170rwkw my torque was 550.2Nm !!!
dam thats ship loads. maybe i should bold an old rb30 in my 32 and bolt on a dirty old turbo. surly that would spin the wheels easy.
hahahah, you can feel the torque, well after owning silvias, r32 gtst, r31 gts with rb25, 300TT, vr4 etc etc.....Like the torque of the RB30.
Yeah turbo on, just sorting out the little problems like getting the raditator flushed today and the flywheel machined (damn vibrations in the clutch made it look like I was a retard trying to drive)
LOL. yeah i miss tourqe, the magan has a bit over 400 nM at the front wheels, and that is GREAT, any gear, bag, your away. Skyline, you need to rev it to get anywhere. LOL.
Well done mate, can't wait to see it.
On an up note, found out last night that my FICD, FIRTS IDLE CONTROLL DEVICE solenoid, doesn't work. See if this makes any differance.
plan B, build the bitch up, pronto. LOL.
That requires money and i owe more than i have let alone coming up with enough to rebuild it.
Im going to strip as much off/out of the shit heap as i can and flog it all along with the rolling shell!!!
Then once thats done im out of cars for a while, IM OVER THEM and all there PROBLEMS
Before you get too excited about torque figures remember a dyno set up in power mode (eg rwkw) will not accurately measure torque.
I mean, if the dyno was set up for a torque reading and you got 550Nm then that's an awesome result, but if it wasn't then there is absolutely no truth in that figure. This was a big problem after the dyno day with Dr Drift when everyone started saying "I have such and such Nm", when all their figures were complete rubbish.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
