woohooo my new hairdrier arived, going topick it up today.
You and trying to be different will be the death of that car :)
Just got an email to say there has been a further delay with my parts so looks like im 100% out of the mega cruise :sick:
yeah possibly, but it sure is fun. If the turbo sux i won't put it on, and send it to slide to put a Rb25 high flow frotn on it. Should be fine though.
Should of just gont a highflow to begin with you twit :)
Im still trying to decide if i want to run the GTR injectors i have or go 550's
you gunna stooge a ride with someone?
My car hasn't even been started yet :rant: awaiting the assesor to approve the quote ($9000)
Well teh turbo might might not be a bit of a dud. Well the thing is defiantly rebuilt, shaft play is as per spec ext, but the thing took 2 weeks to gete here and was wraped in a rag to keep it clean, the box got water damaged the turbo aluminium housing got wet, and now all looks like it's got icicles growing out of it.
I am going to see if i can fix it, if not, i get my money back and a high flow.
AND begor GMB tels me i told you so. I TOLD YOU SO.
not good news old boy, hopefully you can sort it out.
THEN you can sell it and get a highflow like you should of to start with :)
My car hasn't even been started yet :thumbsup: awaiting the assesor to approve the quote ($9000)
No doubt i will, just depends who is going from the south :P
9k damage hey, doesn't sound like a fair insurance reaming at all by the bodyworks :laughing-smiley-014:
and the assesor said i need a new intercooler, one of the fins has been bent since i got it. So now I get a new intercooler, I have to see the bodyworks today to make sure they order the right one, as the one that's on it now is a huge HKS one. So I don't want them putting on a hybred rip off or something.
mmmmmmm
maybe i can get the garbage dude to "reverse" into my car...
DO you think they would buy that the wheels fell off along with the brakes, unbolted the motor and everything else in the engine bay, removed the front bar and FMIC & oil cooler along with a few other things :thumbsup:
I had a look today, and the intercooler did have damage from the acident. Gave the bodyworks the brand and p/n so it all should be good :(
Shannons don't realy care about the cost, it's not their money :rant:
finally got the rest of the kit on, car also has a small photo in HPI this issue for tassie drift series :happy:
Looks great Stu
love the fat vertex look :ph34r:
Im still undecided if i want to kit my car or not yet, will wait till its back on the road first i think :whistling:
are you comming up this weekend stu.
looks like my car will be ready to go by saturday. would be ready to go now if the trail shaft was finshed when they said it would be.
mmmm the sweet sound of a fresh 2.5L
Of course you want to put a kit on your car, 32s look phat with kits...
mine an BN sports by the way...I ran over the vertex at the drift day haha
I've got a vertex kit (has been sitting here for a year and half :happy: ) but if i do decide to put a kit on im keen on something a little different but having trouble finding a supplier :(
The only down side is getting in/out of my driveway and using the car on a regular basis with the clearance issues with a kit fitted :ph34r:
Get some pics up of the change over Dave :whistling:
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
