Diameter and width are fine, but the offset looks too high - I'm guessing that if they DO fit on your car without hitting on any suspension components or rubbing on the inner wheel-arch, then they're going to sit too far inside your guards to look right. They'll be too tucked in.
Also, if they do fit, make sure you use the right holes for your wheel-studs - this wheel is a 10-stud design, 5 of the holes are for a 100mm PCD (Subaru Impreza, Forrestor and Liberty; Audi TT and A3; VW Golf Mk3, Mk4, and New Beetle) and the other are for 114.3mm PCD, which is what your Stagea will use. The hub centre size is also different, so you'll need to get an adaptor to suit - this is VERY important as this is where the weight of your car sits on the wheels, NOT on your wheel studs.
very true...
I was just wondering, is offset measured in mm ? What is R33GTR wheel offset - like, 38? So wouldn't the difference of 2mm be outweighed by the difference in rim width of 1/2 inch (~12.5mm)? Or am I way off here...
Edit: I may have answered my own question here... thinking about it some more... offset is rim-width dependent; therefore it won't be sticking out as much to begin with (and will possibly not look right)... but I think that it can't protrude *in* too far, because the rim is 1/2 inch narrower than a rim which I know to fit, which has a similar offset... I think???
Edited by DaveB
Btw I thought it might be interesting to post up my wheel alignment sheet. The guy who did the wheel alignment wasn't really comfortable with SK's recommended -2mm each side at the rear, because he was worried it would chew the tires out prematurely, so I went with his suggestion of as close as possible to zero front and rear. Nothing I can tell that is different yet, apart from the fact that the steering is still much lighter; the tyres are still coated in too much goo to tell if it is understeering; I will test that later. However by the looks of how things were before this can only be an improvement :blink:
I have noticed more road noise (tyre noise, like a rubbing sound), but this could be a combination of the larger rims/lower profile tyres and the (very) chunky tread design.
Hey all, can someone let me know if these will fit S1 Stag?
Any help greatly appreciated.
yes, they will fit. for what it's worth they will sit ~30mm in from the edge of a GTR wheel and have ~10mm more inner clearance.
i'll reserve my opinion on the actual wheel specs though..
you're on the money, dave. how a rim sits is dependent on both width and offset. offset is measured in mm as a distance from the centre line of the wheel to the mounting plane. the higher the offset the further in the wheel will sit.
if anyone has offset specific questions feel free to pm me and i'll answer them for you :cheers:
Ah, thanks for clearing that up! :cheers:
Wow, sounds like more trouble than they worth! Definately want a rim that is going to enhance the look of the car AND be easy and straight forward to fit. Cheers guys for the help......the search continues....
was at my brothers on the weekend and he had some rims sitting there that i had to trial fit. they are Work Meisters 18" x 10" wide with -3 offset. tyres were 245 40 r18. on the stock suspension they fit, but did hang out of the guard a little bit :P did the front only, the rears were - 20 offset on an even wider rim.
Edited by QWK32
Holy crap, they're WIDE. I have some R33 GTR rims on my S2 and they are 9" wide which looks huge... but yours are sitting an inch outside the guards... looks cool though. Must make it just about look like a steam-roller from the front :P
Bob Jane Racing "Grafic" 7.5" x 17" +40 offset
235/45x17" hankook Ventus-K104
Bilstein shocks lowering circlips w/ stock springs
Nice... that's a good ride height I think. What height is it centre to guard or how many fingers?
Alright, I bought some V35 Skyline wheels for my wagon a few weeks ago because I absolutely love how they look on GorGasm's car.
Wheels are 18"x8" and offset is +30mm. Tyres are Federal 595-SS, 245x40x18 all around. The rear guards need to be rolled as I get occasional scrubbing, front guards are fine.
I'm in :wub: again!
QUESTION: Keep mudflaps, or remove them?
beaut !!!!
very nice.
either or in regards to mudguards, keep em or ditch.
probably keep em on I suppose
love those wheels as well, would love a set myself.
DaveB, the heights are 595 for both front L&R, and around 575 for both rears
hope that helps
the BJR mags are cheap at $100 each
looks awesome Nick, how much did the v35 wheels set you back?
Looks great Nick. Look forward to seeing it in the flesh when I can.
Cheers
Andy
Thanks mate, got them for just under a grand because there are some marks in the finish (as can be seen in the third picture). The marks have somehow cut into the clear coat - might be the result of wheel cleaner not being properly washed off.
Cheers
Andy
Thanks Andy. Looking forward to catching up.
hope that helps
Sorry Tangles meant the centre of wheel to under guard measurements... mine's ~400mm and it's *high* :D
Holy crap, they're WIDE. I have some R33 GTR rims on my S2 and they are 9" wide which looks huge... but yours are sitting an inch outside the guards... looks cool though. Must make it just about look like a steam-roller from the front :)
lol, yeah i didn't leave them on. just wanted to see how they looked.
Btw I thought it might be interesting to post up my wheel alignment sheet. The guy who did the wheel alignment wasn't really comfortable with SK's recommended -2mm each side at the rear, because he was worried it would chew the tires out prematurely, so I went with his suggestion of as close as possible to zero front and rear. Nothing I can tell that is different yet, apart from the fact that the steering is still much lighter; the tyres are still coated in too much goo to tell if it is understeering; I will test that later. However by the looks of how things were before this can only be an improvement :bomb_ie:
You need more castor - i have mine over 5 (can't find the chart ATM) to give more straight lline steadiness at top speeds.
Looked at some 350Z wheels I am bidding on and tried them. They fit fine on my S1 lowered about 35mm. They are 18in by 8 offset +30(5stud x114,3). Potenzas front 225/45 18 rear 245/45 18
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
