yeah tires will be fine
spacers are illigal in some states
i wouldnt worry about the 8mm on the rear, just run a bolt on up front
or get the gktech spacers that come with bolt and slip ons to get the perfect offset
Thanks guys for the help, I guess I will look into running spacers on the front rims.(only coz I can't afford 1k for new rims right now)..with the 17x9+38 on the rears I prob have like mayb 5-10mm space between strut and inside tyre wall, so not sure if its worth the extra $200 to shift the rim 8mm outwards lol I guess I will try to find out if spacers are illegal in WA before i do anything , thanks again :)
Ok, so i spoke to my local Ttf store and they suggested that 235/45/17 tyres would be good on a 17x8 rim as on the 9" rim they are stretched and that's bad for traction/handeling in awd? Does offset change if I go down to a 8inch rim? Cheers
  • 4 months later...
  • 4 weeks later...
Ok last night had the best idear and put some 20X11 + 13 on the rear of my m35 axis but even with the 6 deg of camber I got its still going to need a little bit of guard work
Not 100% about using that 11" wide as don't think there is anyway I would get them on the other end
Didnt you say in the other post you have a wobble in rear end. Could tyre width have something to do with it?
Ok ATM I have 225 tires on both the 8 and the 9" wide rim both 45 profile
So if I keep my rolling diameters the same I should be sweet??
  • Like 1
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
