  • 3 weeks later...
Sorry for digging up an old topic,
Looking at buying a set of 17x9+24 with 215/45r17 tyres for my my series 2 auto.
From having a read through I'm sure the fronts will fit fine and rears may need the guards rolled/lipped?
Thanks
Thanks
They should fit fine, but you should roll your guards anyway. 215s are a bit narrow for a 9" aren't they? (Personally, I'm not a fan of the stretched tyre look.)
Hey guys. Anyone know how I would go for fitment on a c34 rs4s stock suspension. With a 18x9 +12 with 265/35s
These should fit fine too, the RS4S has a narrower rear track than the factory auto. Once again, as per above, roll those guards - 265s might be cutting it really close. I've got 245s on 18x8+30s and there's only about 5mm room.
So I have some 350Z rims fitted to the series 2 auto Stagea - fits well except the front track is narrower than the rear causing terrible road handling - hoping that fitting some 20mm bolt on spacers to the front may help - any oninions? Here are the specs -
Fronts - 18 x 8 +30 running 245/40/18
Rears - 18 x 8.5 +33 running 245/40/18
Here's another person asking for answers!
My incoming m35 has a set of Venerdi 19" 5 spoke chromes on it that I WILL NOT be keeping. (read.. for sale!)
there's so much variation in preferences and all that for tyres and wheel size, offset, width etc.... all I want to know is...
What wheels do I get so that they fit with NO modification.
they will likely be:
19" x width<?> offset <?>
currently wearing 245/40x19"
HALP!
HALP!
19x9 +30 offset would go on no mods; 19x9.5 +22 offset would require light guard lip rolling.
And look 5000 times cooler.
Cheers Daleo, um.. i'm a massive noob.. WTF is guard rolling? is it like flaring the original guard instead of bolt-on (like axis etc)?
Is the max width without rolling, 9?
Seems like there's much less 9 than 9.5 out there. Wish I understood the offset mumbo a little better to make a good call.
I'm thinking about some of these... Haven't got much cash to splash on wheels and tyres.
http://www.ebay.com.au/itm/Rota-GRID-19-x-9-0-20-5x114-3-/150664390583?pt=AU_Car_Parts_Accessories&hash=item23144c27b7
Edited by Kazal
Ok I've just read this entire thread and I'm probably more confused than when I first started...
I have a manual RS4S (series 2) with BC coilovers. At the moment I have Enkei NT03M 18 x 9.5 +27 (with 15mm spacers in the rear; so +12) Tyres are 235 45...AND I still scrub on the coilover in the rear. Going straight is fine, it's mainly bumps, hard corners and heavy offloading onto the back (front is fine)
SSOOO...I'm look at getting some new wheels. 18 x 10, what are people's opinions on offset to sit at least flush with the guard?
Just looking at opinions as I have found a couple of pretty low offset wheels...
Thanks for any help in advance!
- stix
Type 'Rota failure' into Google for me, this is why I generally prefer OEM or forged rims. They will probably be fine though, and the size is about right.
I ran 9 inch + 30 17's without issue, yours would stick out a little at the front as they are 10mm further out.
To get the wheel to clear you may have to roll the guards, which involves using a machine bolted to the hub to roll the lip in and push the guard out a little, especially at the top. You need to heat the paint at the same time or it can crack easily. It's not something many people are willing to do themselves, best off getting some quotes from a professional.
Haha Scotty, I have seen all that, there's about 5 images.. and then 50x12,000 copies of the same ones.
As I understand it, Rota make about 1/3 of the OEM wheels in the market anyway....... So.. interesting that you would say you prefer OEM (I believe ENKEI are responsible for much of the OEM market also).
In other news, what about the Varrstoen wheels?
This car is a daily and being held for eventual resale value mostly. It will probably not ever see a track so I'm not chasing performance wheels, just a pretty fit.
i would swap them the other way! your stagea will loose front grip before it looses rear and in favor of wider rear track on stagea
Everything I've heard about them, they appear to be good quality, very well finished, and stand up to trackwork pretty well.
For a copy of someone elses intellectual property. I'd go for them over Rota's to be honest.
Several Stagea owners have them fitted; maybe check the thread. http://www.skylinesaustralia.com/forums/topic/325613-m35s-wheels-what-wheels-do-you-like-on-your-m35/
The search function is quite useful. ;)
BMW owners seem to be wary of Varrstoens, can't comment on the quality myself though. I suspect that like any other "replica" wheel people will have had good and bad experiences. Yer pays yer money and takes yer chances.
Edited by Hertz Donut
So, you guys are saying that any wheels that cost less than about $2k a set are all just copies, and the quality is (potentially) questionable? Sheehs!
Now I REALLY wish my Stag had OEM's on it.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
