  • 3 weeks later...
  • 2 months later...
  • 1 month later...
Does anyone have a definitive answer on what fits a RS4S? I've read every page of this thread and I'm even more confused than when I started.
I hear we have a bit more room at the back and I'm looking for something quite large either 18 (perhaps 19) x9.5 or x10.5 all around but I'm a little unsure of offsets front to back (back particularly)
  • 1 month later...
This thread helped me so i will post pics.
98 S2 awd manual with 18x9.5 +15 235/40 front and rear. Ride height is 360mm front 350mm rear. Guards are untouched. I did have to play with the front camber as the rims were poking about 10mm. I got it down to 3mm. Rear is flush.
Hi all, looking at new shoes for my stag.
Can I get 18x8.5 +43 on her? She's RWD, not lowered (yet), but looking to S-Tune suspension her
That's a horrible offset, you'd be better off looking at +30 with that width.
They're going to look horribly sunken on the car.
Thanks Erop. I have been wanting to find out if anyone is using greater than 9.5" width on their M35 Stagea.
I'm thinking of getting either 18 x 10 (+25) or 18 x 10 (+15); most likely will be the (+25) given your rear guards required modification so (+15) will certainly be a struggle
Z33Fairlady, 10" width is a bit too much on the ftont. 9.5 +25...22 is the good choice for WB car. 10 inch wheel is as close to knuckle, as it is fitting fender outside. 10 with +25 or more with tyre wider than 245 will probably not fit because of the knuckle.so the +25 is the only inset for 10" rim and 245+ tyre.
PN-MAD, either Black or white rims-i have to wash car twice a week to keep it red, not grey.
  • Like 1
  • 2 months later...
  • 3 months later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
