  • Replies 41
It just sounds like the BOV is too loose. Can you tighten the Blitz unit?
But yes, I'm not a big fan of atmo BOVs either. If my induction is going to make noise on throttle-off, I'd rather it flutter than sneeze.
I put a GFB basic on my car for a few weeks and although I liked the smoother gear changes and didn't mind the sound at first, it ended up grating on me and I removed it. Compressor surge is so much more tolerable than going whoosh every time you back off a bit.
i'd put my money on the BOV needing adjusting.
stalling issues and sluggish acceleration can be due to the spring being too soft. when it vents, the bov is staying open for too long = stall. if you are giving the car shit, the bov may open = crappier acceleration.
not sure about your fuel economy either .. i get just over 12L/100kms, calculated by distance travelled and how many litres it takes to fill up (the only real way to measure economy).
I don't see how an atmo BOV can affect fuel economy. the side effect of an atmo BOV is that the car runs rich due to the air escaping rather than being plumbed back in. But if you were running a plumbback, you would be still using the same amount of fuel .. just not running rich as all the air is still available?
I went the other way around. The car came with the HKS SSQV. If i changed gears next to other people they would jump in their cars. Until i discovered the stalling problems, mind you i have only owned the car for a day lol. Bought a stock plumb back bov. All is good. Still loud enough to hear the Pssshhh
I'm assuming his car's running an AFM. Since an AFM expects the induction to be closed, it will pump the amount of fuel equal to the air that passes through the AFM.
If you're venting air out it'll run rich since you're actually getting less air into your engine than what its measured. On a car with a nicely sprung BOV it'll only run rich on throttle-off, so the exhaust will crackle and pop (and maybe puff some black smoke).
If the BOV is loose and leaking, then it'll run rich on throttle too. Since the thing's not making as much power (if you compare it at the various RPM points) you have to work the engine harder to go as quick.
i found from previous experience in my sil80 that having the spring loose or not loose doesnt effect the stalling issues associated with atmo bov's. that was until i plumbed it back - works a charm now, maybe try that to rectify you problems. funnily enough, the 'line doesnt have an aftermarket bov. personal preference, i dont mind the sound - the sil80 came with the aftermarket bov.
Dido...
Not being argumentative, and not saying you need an aftermarket BOV, but i suspect many of the problems ppl have with aftermarket BOVs is the isntallation itself, not the function
Ive had a HKS Sequential, Super Sequential, Blitz, Apexi Dual Chamber, even a Monza HKS rip off. And i have never had the problems ppl describe. Hell the apparantly crappy Monza HKS knock off has been on my Skyline for over 12 months and it works fine. PPl tell me it leaks boost, but they have never used one, they just hear the name Monza and the stories start to roll. :(
I still run an AFM, and still get about 450kms per tank (city driving) and im running bigger turbo, injectors etc etc ... lol i aint too proud to admit im a ricer. I want as much induction noise, as much turbo whistle, as much BOV and atmo wastegate noise as possible. My god its turbo RB20...turbos are all about strange noises and bless them for it, without it they are just hoovers with no character at all, i mean my crappy old Valiant had a more exciting sound, even with a stuffed timing chain :D
this thread can will go on forever...ppl that have atmo bovs will say they are great and ppl that dont will always say the stock is the best...common ppl since when has anything stock ever been any good...im sure ppl will start saying that stock exhausts and coolers and fine now
If your having probs with your BOV just buy one that vents to the atmosphere and is also plumback use the SAFC to tune and the car will run great no idling probs etc. I reckon whatever floats someones boat really. You like BOV noise then do it, you dont then thats cool too :( We shouldnt alienate someone for wanting their car to look and sound a certain way cause thats the beauty about car modding you can do it your own way :D
Took mine off today and put back the stock one, the stall is just becoming a serious problem and annoying the hell out of me. Having no steering and braking control on a downhill is really making me shit my pants.
my 2c
I got one of the first GFB bov's. GFB used my car for the manifold plate. I have a plumb back one . It does make a slight bit of noise due to my filter and ram tube. Some cars handle dumping to atmos better than others. Remember this air being dumped to atmo has been through the AFM ,and the ecu has calculted the mixture.I think somebody told me you should use plumb backs on Skylines because of this.
Well I did what I set out to do and changed back to the stocker BOV. I had a little hiccup with the actuator hose (when I pulled my stock pipe out of the garage there was a hose attached to it...I have no idea how it got there).
I can tell you that all my issues are fixed now. The car explodes at the 4500 RPM like it used to....It's good to back back to the land of relative quickness.
I've read all the replies and I can take in the fact that the main issue was probably the adjustment of the BOV but to be honest, the sound gets really annoying. My car is also a daily driver and I don't wanna attract any more attention than I already have from the boys in blue.
See you guys around
Reasons stock BOV are good:
They work.
If you want sound, install a pod filter and they make the noise almost as loud as an atmo one.
Cost nothing.
Take no time to install.
Are not defectable.
Reasons stock BOV are bad:
Not loud enough for your taste...
I dont think your argument is valid, noone ever upgrades their floor mats. why? because they do their job well. Maybe if you made them out of carbon fibre you would have a little bit of weight saving?
What RHETT said.
Modifications are only better than "stock" for your intended application.
The stock exhaust does a much better job of muffling than any aftermarket one I've heard. Of course, most people don't replace the exhaust to make their cars quieter...but it depends on your aim. You could probably build an exhaust that flowed just as well as the factory one but was quieter, but no-one wants it.
As another exampled, if all you were running was a cat-back in your powertrain, it'd be a waste of time and money to drop a triple plate, high clamping force, clutch into the car. Sure, its "better" in the sense that its less likely to wear out or break, but your car doesn't need it for your application and now your clutch is a lot heavier and harder to launch smoothly.
The factory BOV does a better job than an aftermarket one in terms of idle quality and suitability in a light tune application. Only when you've cranked the boost beyond the ability for the factory BOV to cope (or you just want some fooli sik sounds to emanate from your induction system) do you need to replace it.
I found the smae problem. My car had the stock BOV and another HKS one along with an exposed POD.
After removing the atmo venting BOV I found response when you change gears was a lot better - it would jump quicker once going into the next gear that is. The sound was still there though.
I bought a stock snorkel and air filter box so now it is pretty quiet. But if you want a BOV noise you can just put on a POD and even the stock BOV makes quite a loud psht as you can hear it through the exposed POD...if thats what does it for you
    • PayPal is a safe, online payment system that enables businesses and individuals to safely send and receive money, making it an indispensable tool in both personal and professional contexts. However, many users wonder how to send money on PayPal? Don't be alarmed if PayPal is new to you - all the steps can be found by visiting merchant sites with links marked "Pay or send money". Once clicked, select payment method, amount, and add message or note for recipient(s). Upon successful transaction completion you will receive an email containing details of transaction. Let’s start by understanding how PayPal works, how money transfers from banks to PayPal and using various payment methods. Moreover, to transfer money between PayPal and bank, head to the Wallet section and click "Add Account", selecting either "Transfer within seconds with debit" or "Transfer between 3-5 days with bank", and following any instructions shown on screen until completed successfully.   How to Send Money Over PayPal: The Basics Before sending money through PayPal, first create an account. Here is how to set-up a PayPal account: ·         Click “Sign Up” on either the PayPal website or app to enter your basic information such as email address or name into their system. ·         Link your bank account, debit card or credit card directly with PayPal so you can fund transactions directly using these accounts. ·         Verifying your PayPal account will enable you to send and receive more funds. Typically, PayPal requires that you verify your credit card or bank account by making small deposits into it. ·         Once your PayPal account has been established, you can send money through it.   How Do I Send Money to Someone on PayPal? After creating a PayPal account, you can easily send money through it. Here is how to send money to someone on PayPal: ·         First of all log into your PayPal account ·         Once on your dashboard, click on "Send & Request Tab." ·         After this enter the recipient's email or mobile phone number. ·         Enter the amount you wish to send to someone. ·         At last, recheck all the details and click "Send Payment" to complete your transaction if everything looks in order.   How Can I Send Money PayPal for Goods and Services? PayPal provides a safe method for individuals and businesses alike to transfer funds online, both personally and commercially. When paying for goods or services there are additional protections in place both for buyers and sellers. PayPal Buyer Protection offers you peace of mind when paying for products or services with PayPal. In the unlikely event that there is an issue with a transaction, if there are any discrepancies you may dispute it and be eligible for a possible refund. You need to follow the same steps to send money, but select Paying for Services or Goods when prompted. In fact, this extra layer of protection will keep your account safe from fraudulent attacks.   How to Transfer Money to PayPal from Bank? Here is how to transfer money from PayPal from bank: ·         Log into PayPal using either its app or website. ·         Click "Add Funds" in the Wallet section, and add money directly from your bank to your PayPal account. ·         If you have linked your bank account with PayPal, select it under Funding options to select it as your funding option. ·         Enter the amount you would like to transfer to PayPal from your bank balance. ·         Click Add Funds. It typically takes several days for funds to arrive on your PayPal account.   FAQ How can I send money PayPal? Log into your PayPal account, select "Send and Request," enter in your recipient's phone number or email address, select the amount due, payment method of choice and click on "Send Now" - quickly and safely sending money via PayPal is now an efficient method of money transfers!   How do I transfer money to PayPal from a bank? Log into PayPal and select "Add Funds" to transfer money from your bank to PayPal. Select your account number, input an amount, and confirm it. Though the transfer may take up to several days for completion.   How do you send money to someone on PayPal? Simply log into your PayPal account, select "Send and Request", enter the recipient's phone number or email address, select the amount to send, and click "Send Now".   How can I receive payment through PayPal? Senders can easily accept payments with PayPal by providing your PayPal email address and being notified via email when a payment has been completed. When funds appear in your PayPal account, they will appear instantly!
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
