Had my car tuned at Tunehouse earlier in the week. Very impressed with the setup there and the help and advice and overall professionalism of Jim and co!
The dyno room is one very impressive setup! :blush:
OK, Plug over, now onto the details... :(
Specs:
Standard RB26 with no internal mods (so boost kept to max of 1.2Bar)
Apexi Power FC
Greddy profec B II EBC
Trust T517Z Turbos (8cm... I believe)
Trust dump pipes.
HKS front pipe
Midori Cat
Fujitsubo Legalis R cat back.
Trust/Greddy Radiator and Oil cooler
Tomei cam gears
Nismo 600cc injectors
Nismo FPR and Fuel Pump
Splitfire coils
Greddy panel filter in standard airbox.
Everything else engine related is standard...
Nismo Super Coppermix Twin C-Spec clutch.
Result:
328.1awkw at 18PSI
513.8 Nm
(second line shows a run @ 14psi)
Had new setup put on dyno today at PITS aka matt spry.The guy never dissapoints.Car made 513.6hp on 1.5 bar on bp 98 and makes very strong power all the way to 8750rpm which is where we set the rev limit.comes on hard by 4500 and the mid range is so strong all the way to the limit.Fuel system and engine can handle alot more but turbos where just about at there limit.
Specs- R33 GTR v-spec
Nismo RR581 turbos
HKS acuators
New n1 block
Apexi power fc
cp pistons with the harder rings
Acl race bearings through out
Spool rods
Arp head,rod and main bolts
Nismo full gasket kit
N1 water pump
ATI 1000hp balancer
New o2 sensors
New Knock sensors
New idler bearing kit
New Gates belts
Greddy cam gears
Tomei 270/10.8 in /ex
Tomei Type B springs,retainers and solid lifters
Tomei oil restrictor
Tomei oil pump
Tomei fuel reg
Hi octane 9ltr custom gated sump
Oil return from head to sump
Head mild port
Standard manifolds match ported to head and turbos
600x300x100 Trust intercooler
PWR custom 75mm Radiator with built in oil cooler.[Great investment}
PWR Header tank
Oil and water temps dont rise much over 82
Trust full piping kit.
Z32 AFM x2
Nismo oil air seperator
Spitfire coil packs
ORC twin plate clutch
Custom extended clutch fork[Clutch feels so lite]
CES competion dump pipes
3 and 1/2 inch system with 4in cat,
Front and rear diff gears out of gts4
Power enterprise 800cc injectors
1.7 ltr surge tank with intank sard pump and 2x bosch 044
513.6hp at 1.5 bar
Edited by JGB33
Dyno Update:
1998 R33 GTR
RacePace Stage 1 Engine
Tomei cam gears
Garret 2860R-5
700cc Sard Injectors
Apex Power FC
HKS GT Spec Intercooler Kit
Apex pods
HKS Front Pipe
Nismo cat back exhaust with De-Cat
Nismo Twin Plate Clutch
Running ~ 1.2 bar
Everything else is Stock
Benno advised it should easily hit 350rwkw with a better cat back exhaust and more boost.
(The search now begins for a better exhaust)
First dyno done on my car about 6 months ago, I was very impressed with the clean power line and the steady 11PSI held all the way up to 293rwhp. Will get a Power FC and get it dynoed again...
1993 R32 GTR
Retuned 28/Mar/2006
120,000kms
3" Mandrel bent zaust
R34 ball bearing turbos
front dump pipe
HKS pods
Power FC D-Jetro
PRofec B-Spec II (0.9bar)
305rwhp
228rwkw
http://img92.imageshack.us/my.php?image=dynosheet26mv.jpg
Retuned 11/Oct/2006
123,000km
**Added
Tomei Cam Gears
Nismo 600cc Injectors
Nismo Timing Belt
Nismo Fuel Pump
Nismo FPR
Nismo 62deg Thermostat
Cooling Pro 3-core Radiator
322rwhp
240rwkw
What could you get out of
HKS GTSS kit
4in pipe turbo Back
Apexi Power fc
700cc
bosch 044 fuel pump
  • 3 weeks later...
HKS GTSS kit
4in pipe turbo Back
Apexi Power fc
700cc
bosch 044 fuel pump
Well my 32gtr made 328rwkw with
hks gtss kit
3" hks exhaust de-cat
hks 600cc injectors
tomei cam gears
nismo fuel pump
hks cooler kit (unsure which one)
power fc
sard fpr
stock airbox and filter
running 22psi tho :P
Edited by topher_
This is the dyno from the previous owner. I've had the car since may but has since munched a bearing so it's now receiving a 26/30
That said these are the details;
Supposedly forged internals ( haven't pulled the sump of yet to check)
Tomei 260 9.1cams
Greddy cam gears dialed in
Sard 700cc injectors
Apexi pods filter
Z32's
PowerFC
Blitz boost controller
Stock intercooler :)
N1 turb's
Double dump pipes
Tuned front pipes of unknown brand but beautifully made 2.75 inch into 3
3.5 inch ex from cat back massive canon - car is very quiet! Can't hear the engine at 100km/h
Single plate clutch which was fine, but fcuked now from over exuberant launches by previous owner.
044 in tank
Boost peaks at 22 trails off to 17
Very nice to drive
573whp @1.6bar on my r34 gtr
splitfire coilpacks
greedy sparkplugs
mines rocker baffels
hks camshafts
acl rod bearings
acl main bearings
tomie 1.8mm head gasket
tomie oil restrictor
tomie rod bolts
n1 water pump
n1 oil pump
uprated 10lt big winged baffeled alloy sump
hks gt2530 modified turbines
hks turbo elbows
hks cam gears
hks cam belt
rc 800cc injectors
greedy light weight pulleys
middlehurst oil seperator
apexi power fc
apexi boost controler
nismo air flow meters
koyo radiator
nismo radiator cap
nismo oil cap
greedy cam cover
hks drag intercooler
hks full hard pipe kit
hks rs hard pipe induction kit
nismo oil cooler
hks titanium 4" drag exhaust
ava dowmpipe
nismo gear box oil cooler
nismo rear diff oil cooler
6 speed getrag gearbox
ats twin plate carbon clutch
ats lightweight flywheel
Garrett 2860-5s
Sard 700cc Injectors
Sard Fuel Reg
Bosch 044
Forged CP Pistons
Nitto H-beam rods
HKS 272' cams
Extended and baffled sump
HKS dump pipes
HKS FMIC
3.5inch Trust titanium exhaust
Apexi power FC
HKS EVC 5
NI water pump
Nitto oil pump
Heaps more...
Made 347.3awkw @ 20.7psi of boost at CRD
Will make more when the cam timing is adjusted.
  • 4 weeks later...
  • 3 weeks later...
R33 GTR
Nismo fuel Pump
Power FC
Sard 700CC injectors
Trust Drag Cooler
Kakimoto Exhaust
X-Force Cat
Tomei Cam Gears
HKS dump Pipes
HKS-GT-RS turbos
Stock Airbox
330kw@18psi - Morpowa
Edited by BIT SUS
Got My car tuned today at Status Tuning by Trent and what a great tune. Running 293rwkw on 16psi full boost kicks in around 4500rpm.
Ill post my results tomorrow.
gt2860r-5
Apexi PFC
Tomei Fuel pump
Nismo AFM's
Sard 700cc
HKS cam gears
Tomei dump pipes
3" exhaust system
1996 R33 GTR Vspec
Mods:
Link G4 Extreme ECU
Trust 88mm forged pistons
Nitto Race I-Beam rods
ACL Race big end bearing
ACL main bearings
Nitto Drag series 1.2mm head gasket
Nitto Drag series gasket kit
Trust sump extension
Stage II head port/polish/shave
Block bored/honed & bead blasted
Tomei 260 Poncams
Trust valve springs
New Nissan valve stems
Nissan N1 water pump
JUN high flow oil pump
Tomei adjustable cam gears
OS Giken timing belt
Garrett 2860r-5 Turbos
SARD 700cc injectors
SARD fuel reg.
Bosch 044 Fuel pump
Splitfire Di coils
100mm Front mount intercooler plus piping
KKR hard piping kit
Trust stainless Oil catch can/washer bottle kit
Braided Breather Hoses
Trust remote oil filter/oil cooler kit
Trust Pod Filters with custom airbox
Engine covers, plenum & turbo compressor pipes high temp powder coated (blue)
X-force stainless turbo dump pipes
Trust front pipe
Trust high flow CAT
HKS Hi Power 3.5" exhaust
Greddy Profec B spec Boost controller
HKS Turbo timer
OS Giken STR twin plate clutch
Gearbox rebuilt with new series III R33 GTR parts
After 3 months of work, we finally made this at 20psi...
Thanks to all the boys at ADVAN Performance for all thier efforts.
R34 GTR vspec
power fc
sard 800cc
sard fuel rail
turbosmart t-reg 800
Bosch 044
garrett 2860-5
hks dumps
hks front pipe
turbosmart boost controller
splitfire coils
1.2 bar
304kws at all wheels
done by CRD in sydney
Edited by trvgtr
R34 GTR V Spec
Engine specs a secret but to say I have spent approx $70,000 and still 2.6 ltr
Autronic SM4 with Autronic CDI
crank trigger
Aqua mist water/methanol injection
460 KW at all 4 wheels on 1.45 bar
569 KW at all 4 wheels 1.9 bar
Tuned by CNJ motorsport in Brisbane.
  • 3 weeks later...
Hey guys,
Build is as follows;
OS Giken twin plate super coppermix clutch kit, nismo strong release fork pivot, nismo big operating slave cylinder 4" Stainless steel exhaust including X-Force turbo dump pipes with HKS front engine pipes 5" HKS Cannon muffler Splitfire coilpacks, APEXI Power FC, APEXI RSM, HKS 660cc injectors, HKS Fuel rail kit Nismo fuel pump Nismo fuel pressure regulator, Trust 4" intercooler, Trust intercooler piping kit,
HKS air filter kits x2
N1 R33 turbos
Engine fully professionally rebuild 300kms ago
Arias pistons
Nismo rings
Eagle rods
Block was torque plate honed for exact clearancing
Nismo oil pump
Crankshaft x-rayed and magnafluxed
Nismo main and big end bearings
tomei 2.0 mm multi plate steel head gasket with oil restrictor kit
ARP head studs
Head fully serviced, valves guides and seats replaced
Light port and polish done as head flows very well from standard
Throttle bodies and inlet plenum port matched perfectly to cylinder head
HKS cams - 264 inlet and 272 exhaust, 10mm lift
Car Made 431rwhp @~16 Psi
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
