r32 gtr v-spec
stock rb26
adjustable cam gears
nismo fpr
apexi front pipes
high flow cat
apex cat back
stock dumps
stock turbos
apexi pfc
apexi boost controller
apexi pods
stock fuel pump
stock injectors
253awkw on 10.5psi
  • 3 weeks later...
1998 Stagea 260RS
Standard bottom end
GT3582R .82 external gate
custom steam pipe manifold
3 1/2 inch from turbo to cat 3inch cat back
xspurt 1000cc injectors
standard head & cams
haltech platinum pro plug in
bosch 044 in surge tank
standard gtr pick up in tank
turbo tech boost controler
407.4 HP (303KW) @ 20PSI on caltex 98 safe daily driver tune
Edited by GTR260
Can finally post in here...
1995 R33 GTR
Garret -7's
Tomei Adjustable Cam Gears
17psi - Racepace mod to actuators
Reco Head
Hiflo Cat
Ganador Exhaust
HKS Pods
Splitfire Coilpacks
Apexi Power FC
Stock Bottom end
Stock everything everything else; Injectors, Dumps, Front pipes, AFM's, Cams
295.8 rwkw
Edited by Booki
1993 R32 GTR
Stock engine
Stock fuel pump/injectors etc
R34 N1 Turbos
Nistune
Greedy intercooler piping
HKS induction
HKS Hi-Power exhaust
268rwkw - at approx 13-14psi (boost restrictor removed)
1989 R32 GTR
Built engine
Walbro 460 fuel pump/ID1000 injectors
R34 N1 Turbos
Power FC
K&N Pods
HKS dumps, aftermarket front pipe, 3" high flow cat-3" exhaust
325rwkw - at approx 20psi tapering off to 16psi on E85
http://imageshack.us...1220211932.jpg/
R33 GTR Vspec
Fully Forged Motor
Single T04z 1.00AR
xforce single manifold
Xforce exhaust 3.5 inch exhaust
dual port bovs
1000cc ID's
Haltech Pro Ecu
Hybrid 130mm drag intercooler
Greddy Cam gears
*standard cams
Bosh intank fuel system
upgraded fuel rail
315kw @ 14psi
410kw @ 23psi
Stock N1 - performance mods; pretty much minimal - Power FC D-Jetro
319.5 @ 21psi
I forgot to post this up in July sorry. Fuel consumption afterwards = 14.3l/100Km on mountain roads.
R33 gtr Vspec
stock internals
Garrett -5s
tomei dumps,Crd front pipe,100 cell cat,3.5 in exhaust
tomei cam gears, cams 250-260 ???
720 injectors,Haltech platnium pro
331awkw @ 20 psi
nitto 2.7 full stroker kit,9L sump extension,crd full race head(not the cams)
n1 oil and water pumps
im still runinnig the engine in will post new results very soon
  • 2 months later...
2000 GT-R 34 v spec II
Stock RB26 internals. Cams, pistons and bottom end.
Nitto head gasket and ARP studs.
Ati balancer.
2000cc ID injectors.
Hypertune 90mm single throttle plenum.
HKS 100mm cooler.
Garret 2860 -5's.
Wolf v550 ECU.
Ported Manifolds.
Spitfire Coil packs.
Walbro 400lph pump.
Adjustable cam gears.
full titanium Exhaust.
n1 water pump.
n1 oil pump.
Koyo radiator
414.5kw at the wheels on 21psi. E85
2000 S15 Silvia.
Stock RB26DETT R33
Valve springs
555 injectors
2860-5s
Walbro 255
N1 water pump
etc etc etc
300.1Kw on 22psi Pump 98
Ran out of fuel to push it any more.
New setup;
GT Block
Tomei 2.8 (87 mm pistons with Titanium top ring)
9.0:1 compression ratio
260 at 10.65 cams. (custom grind)
Full effort HKS/NAPREC head. (1.5mm OS valves, NAPREC CNC machining, intake squish pad removed, decked 1 mm)
Ported manifolds (to head and turbine housing)
Nismo 0.9 mm head gasket
Nismo Plenum
Nismo intercooler
Tomei series 1 dumps
Garrett -5's
Racepace motorsport twin 3 inch exhaust
Blackbox ECU (This ECU is yet to be released for GTR's)
Ethanol flex fuel setup
Ross Tuffbond crank trigger. (Timing is no longer taken from the CAS)
Stock airbox with a $10 paper filter in it.
United E85
Modified turbo intake pipes
Made 472 RWKW with the EBC on (highest was 474). Peaks at about 28 or so then trails back to 25.5 ish top end. With the EBC off (20 PSI) it mate 441 RWKW. We only did 10 power runs with no cam fiddling so there may be more left in it. Tuning for very strong midrange midrange more than anything.
972FDE76-81E2-40D4-9009-FED29B987CB8-174
Engine Bay:
R33 GTR RB26DETT
R33 GTST 5 speed manual
Nismo 600 cc injectors
Nismo Coppermix clutch
Superspark coil packs
Garrett 2860 -5 turbos
HKS adjustable wastegates
New Bosch water pump
New genuine timing belt
New valve springs
RB25DET sump
HKS HighPower exhaust (modified)
Koyorad twin core copper radiator
R33 GTR FMIC (modified)
Electronics:
Power FC D-Jetro (No AFMs)
HKS Profec-B boost controller
HKS turbo timer
100% duty cycle too. Where am I going wrong???
- -5 turbos
- HKS Dump pipes
- Tomei expreme manifolds
- Tomei cam gears
- Tomei 260 9.15mm camshafts
- Trust Front mount
- Full 3.5inch exhaust
- sard fuel regulator
- splitfire coil packs
- sard 800cc injectors
- apexi power fc
- Hks fuel pump
- z32 AFMs
- HKS fuel rail
354kw at all fours on 20psi
1996 r33 gtr v spec
nitto oil pump
9 litre sump extension
arp main and head studs
acl race bearings
ATI balancer
nitto rear oil drain kit
CRD race head
700cc inj
-5s
tomei dumps
CRD front pipe/high flow cat
3 1/2" exhaust
splitfire coil paks
haltech platnium pro
Next E-flex fuel
  • Like 1
99 R34 GTR 2300ks since rebuild
Motor rebuild which I did myself apart from ring gaps and block machining.
CP forged pistons 86.5mm and rings
Metal head gasket
New bearings std
N1 oil pump with remax chrome Molly gear set.
machined bores with shaved block
N1 water pump
-5 turbos
Nismo 600cc injectors
Nismo fuel reg
Nismo High flow fuel pump
Power fc + boost control kit
K and n air filter
Custom lobster back twin turbo pipes
Nismo copper mix twin plate clutch
Nulon 5/30 oil
Nissan coolant
Nismo exhaust
Nismo oil catch can
Greddy Aluminium radiator
Running 1.5 bar
No oil control issues
  • 3 weeks later...
96 R33 GTR
ID 1000's
Nismo Fuel Pump
Apexi Pods
-9's
HKS Actuators
Power FC
HKS Cam Gears
HKS Dump Pipes
HKS Front Pipe
Single Cell Cat
HKS Hi-Power Silent
Nismo Coppermix Twin Plate
314kw @ 18psi
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
