There is some info on the EFRs on this thread, might help .                 "Borg Warner EFR Series Turbo's V 2.0"
From what I have seen the 8374 should liven it up a 1000rpm ish earlier , looks like it really gets going @ 4000 RPM now :)
Updated dyno from yesterday's tuning session. Increased timing from factory Haltech up 3-4 deg. Also increased boost from 17-18 up to a pretty solid 20 psi. BIG changes in HP. This 8374 LIKES THE BOOST. So the car is up about 50 whp over last time at the drags so it should be 10 sec pass on street tires and pump gas this time around. Also they just finished two E85 stations around my house so get ready for REAL power soon!
Getting FUN! Here's comparison to last time at the dyno. Also on this dyno a stock C7 Z06 put down 571 HP/576 TQ so with 14% drivetrain loss it's right at factory claimed 650/650 for comparison purposes (for whatever that matters).
Build is 2.75L BC Stroker crank on stock bores
Tomei Poncam A set 0-0
ported head
BC SS valves
Hypertune V2
CP valve-relieved pistons
BW 8374 IWG .92 turbo
6 Boost Divided T4 manifold
  • Like 2
8 minutes ago, ido09s said:
Have you had a chance to race this yet?
keen to hear what mph it runs ;)
134MPH.... didnt stack up to power.... could be due to:
- Not having the boost it was tuned at on the night - should have had 31psi but it was running 29psi
- Me taking it easy during gear shifts due to standard box
Will go back eventually.... blew the box 2 weeks ago so might wait until I have something stronger.
Edited by usmair
All dynos are different mate, even wheels/tyres will make a decent difference. I don't think its too far off the mark though. Our car makes 485rwkw at 23psi and runs 138mph. Unigroup is known to have a bit of a tough dyno though.
Its still decent mph that your car runs. I wouldn't be too concerned about it. Get the box done and race it :)
Edited by ido09s
  • Like 2
  • 2 months later...
  • 3 weeks later...
On Monday, June 20, 2016 at 7:07 PM, .R33. said:
On Wednesday, May 04, 2016 at 5:03 PM, .R33. said:
Hi all just got my R33 GT-R le mans tuned.
Unopened r33 rb26 done just under 100,000 (whether it is legit or not lol)
Mods:
r34 n1 turbos
Ported stock manifolds
Split dump pipes
Xforce front pipes
100cel cat 3"
3.5" cat back
Apexi pods
Trust fmic
Hks evc-5
Link g4+ ecu (no afm's)
Siemens 660cc injectors
Nismo fuel reg
Walbro 255
OS Giken twin plat clutch
Probably more i missed.
Made 300hp on 14psi
365hp on 20psi
Was hoping for abit more after seeing some of the results here, but tuner said to do cams/gears/springs and should get near the 400hp mark.
Added a set of tomei adjustablecam gears. Car now makes 385hp atw 18psi on 98 :) dropped 2psi and gained an extra 20hp...
Impressive gain, wish i did it sooner!
Got the gtr flex fuel tuned.
Added a set of splitfire coils, 3.5 inch decat(4inch body), 1000cc injectors, walbro 460 pump hardwired 14v, modified twin turbo plate (divider welded in) ethanol content sensor.
437.7hp @20psi on e85
  • Like 1
2 hours ago, ActionDan said:
You happy with the response given they are N1s?
Yes pretty happy, feels like they come on full boost quicker than the dyno paper says. Only driven it twice sine i picked her up and havent really looked at rpm and boost.
seriously look @ cam gears, should be getting full boost quite a bit before you currently are...
perhaps also consider different dumps if they are the short splits...down the track...
Tomei Cam gears were put on last year. The dumps are the short split type, when i change turbos to -9's or -5's i will eother go bellmputh or the longer split dumps with matching front pipe. When should i be seeing full boost by? Cheers
Daniel, I would expect -7's to see fullboost (18-20psi) by 4000RPM, give or take a couple hundred RPM...
If you have cam gears already see what they are adjusted to...
https://www.youtube.com/shared?ci=xD3jOhM_COY
  • Like 1
Here is my results
R33 GTR
stock head apart from arp head studs n tomei type b valve springs n retainers
gtw3884r 62mm 1.00 ts
6boost ts t4 mani
turbosmart 60mm gate
3.5" tbe
100mm fmic
bosch 1000cc
walbro 460
turbosmart v2 1200
  • Like 1
