This thread was started some time ago but read till end for follow up.
I here this expression frequently, some times in different context .
What does this mean exactly please?
How do you do it?
Why is super gromet style metal head gasket not sufficient? Or is it. <_<
An O ringed block will have a groove machined around each bore and a steel ring pressed into the groove. This will apply significantly more pressure to the gasket to prevent it blowing out under higher internal combustion pressures.
It is often accompanied by a matching groove in the head to further trap the gasket. Block O ring (if yoou are getting machining done) costs less than a metal gasket including the OEM gasket.
Wouldn't mind a wiki set up with technical terms like these.. great description GTRGeoff wasn't too sure of it myself..
Good idea :) Wiki's are useful and we can tell everyone to search the wiki instead of the woeful forum search.
Good idea :( Wiki's are useful and we can tell everyone to search the wiki instead of the woeful forum search.
What do you mean woeful?
There is nothing wrong with the search functions of this forum.
I use it so often and within 5 mins tops ive found what i was looking for, or enough information to make more questions.
Well make one yourself, maintain it yourself and submit it to the Admin
(i guess thats where the idea stops eh?)
Here's a link to a wiki that i was playing around with a while ago, dont have a lot of spare time at the moment though. If we can get enough useful info on here i'll register a proper domain name for it. Most of the info can be cut and pasted from other places on the net.
Skyline Wiki
This is not something for backyard mechanics, but a specialised engine machine shop will have no problems sourcing and fitting.
So is it better than a quality metal grommet style gasket or simply cheaper because one can use a cheaper gasket ?
I assume that one could not use a metal gasket if it hasbeen O ringed?
Skyline Wiki
Fatal error: Call to undefined function: getspecial() in /home/content/b/3/3/b33st/html/wiki/index.php on line 97
:lol:
If you wanna talk about setting something up, im more than willing to help with it all, simple enough to do id imagine.
Just gotta have the interest.
People use both, as posted above, but it depends on your power requirements.
The gaskets ability to hold pressure is the combination of its own structural strength at its weakest point, the clamping pressure of the head and head bolts, the evenness of the clamping pressure and any ancilliary aids to retention such as O rings or W rings. I've used an RB30 gasket modified to fit the RB25 at a time when RB25 parts were scarce and I had to move the car from Canberra to Melbourne and eventually it just pushed the gasket sideways into the water gallery. Blowing the head gasket could be from displacement, warping of the head, corrosion/poor preparation or a combination of those. The rings help prevent displacement.
Edit: as for is it better than the super grommet gasket, that is using stock gasket and O ring, I don't know. You would have to be producing some massive power for it to have to need better, and so cost would be little inconvenience and you would use the best of everything.
Thanks  for your oppinion Geoff,
i understandall what you said . My main piont and question is that many people use the term O ringedblock as if it is something super special  where i now see it as simply an cheaper alternative( in the long run) than an expensive quality gromet style aftermarket head gasket.
I will run with my Tommie super grommet and new ARP studs for now.
Thank you all for yor input.
Dave, A quality metal head gasket is upto just about anything you want to thro at it with most big power cars using them but the Oring adds that much more reliability in massive boost cars tuned to the limit like you plan for yours. When using an Oring on a metal head gasket it can take days to settle needing to be retensioned a few times before startup and then retension after its been run.Many 1000+hp cars run the metal gasket alone without trouble but at about $130 to Oring it wont add much to a major buildup and does seem to help if you overheat your engine and leaking after overheating seems to be the only weakness of metal gaskets.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
