  • Replies 343
the world or international email support is a funny thing.
I sent many emails to world of warcraft while I was playing that and never got anything but automated responses telling me someone would get back to me, which they never did.
had similar things happen from a lot of companies.
https://www.sau.com.au/forums/topic/102081-nengun/page/4/#findComment-1886383
I have sent probablly 11 email to neugun now about a nismo key i purchased that never arived....
Bought it back on the 5th of December....
The tracking system says its delivered but i have never recieved the key....
No responce to my emails... Im just gonna cut my losses... Nothing i can do....
https://www.sau.com.au/forums/topic/102081-nengun/page/4/#findComment-1886871
same with my clear indicators..
been about 2.5 months now...
i find it funny on there website they actualy say something along the lines of
'were not dodgy... we've been in business for a long time'
https://www.sau.com.au/forums/topic/102081-nengun/page/4/#findComment-1886910
They don't offer phone support.
They can be difficult in contacting but I have recieved about 10 orders from them without any drama, apart from the time issue.
Col-GTSX - If the tracking shows your item arriving in Australia, looks like someone at your post office may have worked out what it was and pocketed it. Can't fake the tracking with EMS.
https://www.sau.com.au/forums/topic/102081-nengun/page/4/#findComment-1887141
Yeah i understand that its been pocketed here... But i though $14 worth of EMS postage for a 100gram item would include insurance...
Im a little peeved because they wont even write a email back to me. I mean I was under the impression that it was insured when buying it. I was gonna get a HKS Turbo kit from them but now im not gonna buy anything else... Due to lack of communication and no infomation about insurance on postage...
I have contacted EMS they said it was delivered to Sydney International Airport. But no further info from there. I mean this means it has not got to my door. EMS also said the package was not insured. So im at a loss of $60-$65....
Arhhh well....
Im not saying dont buy from them cause i have never had a problem before... Just this time im really disapointed....
https://www.sau.com.au/forums/topic/102081-nengun/page/4/#findComment-1888206
I got this email from a sau member in AUG05
Hi,
My son has spent thousands using Nengun. He works overseas for half the year and I get to sort out the problems when his gear doesn't arrive here.
Every time he swears "That's the last time I use them", but he goes back as the prices are very good.
He first got a PFC. They sent the wrong one then argued it was my son's fault. As we had all the e-mails it was quite clear whose fault it was. The correct one turned up months later and we had to on-send the wrong one to someone in Perth before Brent would do anything. Then an Apex boost kit and fuel reg. These arrived before the PFC which was real handy.
After long discussions with Brent who swore all the problems have now been sorted, my son just bought a KHS GT2835 complete turbo kit and Nismo injectors. The kit has a HKS F-Con Pro included, comes with the kit, can't be bought without it. Comes direct from HKS with it. So guess what's missing from the kit?
Without fail, the goods have always arrived before the EMS number even worked. And without fail, there have been problems.
Regards,
https://www.sau.com.au/forums/topic/102081-nengun/page/4/#findComment-1888233
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
