I have a 1993 r32 GTS-T
Got:
FMIC
K&N Pod
Cold Air Intake (diy job)
Sard High Impedence 550cc Injectors
R33 S2 turbo (off an auto with about 40,xxxk's, never seen more than 5psi), got it highflowed by a joint in dandenong (forgot name now), but $1200 later with garrett internals its rated at 350hp
Split dumps
High Flow cat (shit condition, getting replaced next sat)
3" catback 4.5" tip (also being replaced next sat)
Dr Drift ECU Remap
Dr Drift Boost controller running 16.5psi
Bosch 040 Pump
Was originally running 210rwkw, then the cat started collapsing in on itself, so dr drift (sam) backed it off to 200kw for now, but with the zorst fixed should easily be back at 210.
I use it for work mostly, and i drive to the northern suburbs a bit, its great for a daily drive, and completely hauls arse when i put my foot down. Spent about 6-7k on the engine so far, well maybe 8, but its so worth it, rb20's can go with a few sensible mods :banana:
1992 R32 gts-t
-RB20DET w/ 205k kms
-Stock Internals
-Stock Turbo
-Stock boost
-Stock ECU
-Stock fuel system
-3" Cat back Exhaust
-No Cat
-BLITZ LM Suspower pod
-600x300x75 FMIC w/ 3"piping
142.2rwKw @ MRC Performance Castle Hill
This was recorded with a dodgy AFM as well running so rich that at times it was off the scale!!!
1993 R32 gts-t
- RB20DET w/ 100000 kms
- Stock Internals
- Stock Turbo
- Turbotech Manual Boost Controller
- 12psi, dropping to 11psi
- SAFC2
- Walbro pump
- 3" Turboback Exhaust
- Apexi pod
- Just Jap FMIC
First tuned run was 168.5kW
Last run 162.5rwKw @ Unigroup Engineering
Edited by mark_sudakov
After 4 months off the road I just got it back, goes really well.
Internally stock RB20
K&N Pod and shield
Full 3" exhaust and dump pipe
Intercooler
GTR Injectors and uprated fuel pump
Hi Flo R33 Turbo, steel wheels etc
Turbosmart fuel pressure regulator
Bang on 200rwkw @ 16psi, full boost at 4500-4600 rpm
K&N Pod and shield
Intercooler
Opps forgot to mention a couple of important bits to my list above
- Z32 Air Flow Meter
- Chipped by Robin at Torque Performance
Edited by R31Nismoid
RB20 Onevia
dynoed last year with:
JJR fmic + custom piping
Drift pod
3 or 3.5" cat back
everything else stock
made 151.1rwkw at 10.6psi
now has a 3" metal cat and JJR 19 row oil cooler and 12psi so should have a little more.
Edited by RB ONEVIA
  • 3 weeks later...
92' R32 GTS-t Type-M
Mods:
- Internally standard rb20
- Hybrid FMIC
- Apexi Power Intake POD
- GK-Tech split dump/front pipe 3"
- high-flowed cat :P
- Blitz Nur Spec-V Cat-Back
- Bosch 040 fuel pump
- RB25 turbo w/rb20 actuator
- Turbotech Boost Controller set @ 13psi
- CEF11E remap
186.8kw atw
Graph:
  • 3 weeks later...
1993 R32 gts-t
- Stock Internals
- Stock Turbo
- SAFC2
- Walbro pump
- Apexi pod
- Just Jap FMIC
Have you stolen my car mark? haha
RB20DET
Bosch 044
Intercooler
3" Exhaust
Turbotech Bost controller on 13psi
Stock Internals
Exactly same power = 162.5rwkw -> Boost Worx. Will post dyno shoot soon
my R32 as of last week.
o2 sensor was faulty so it got replaced...two lines are before (blue) and after (green)
pretty happy with the power...i think my tuner said it was running 10PSI (no boost gauge) even though there is no bleed valve...other mods are 3", pod, intercooler.
madness
129000km RB20DET
Stock internals
Cheap Chinese T3/T4 turbo (.50 front, .63 rear)
Front mount
GTR injectors
3inch Exhaust
38mm External wastegate
80mm throttle body
Front facing plenum
Adjustable cam gears
Big fuel pump
Plug in LINK GTS computer
Pod filter
Tuned By NZEFI in Christchurch, New Zealand
351hp/262kw @18psi
1993 R32 GTS4
RB20DET
Stock Turbo
Stock ECU
3" turbo back exhaust with hiflow cat
FMIC
HKS green Pod
CAI
Turbotech Boost Controller set at 12psi
made 181 RWKW at fisher performance
  • 3 weeks later...
1993 R32 GTS-t
Standard RB20
ARC 105mm SideMount intercooler (50% larger than r34 gtt)
SplitFire Coilpacks
Apexi Catback
Batmbl Split Front/Dump 3inch stainless steel
Xforce hiflow cat
GTR Fuel pump
3A Raciing Airpod
HKS GT2530 with rb20 actuator
Standard Ecu - No Tune
Standard Injectors - maxing out
A lot of thanks to ReCustoms - www.recustoms.com.au
1992 R32 GTS-T
RB20DET (Stock internals) 165 000km
HKS GT2530 on 14psi
Bosch 023
Sard Fuel Reg
Stock Injectors
Stock ECU
FMIC
Pod
Oil Cooler
272hp
Now with tune!!!
RB20DET (Stock internals) 170 XXXkm
Splitfire Coilpacks
HKS GT2530 on 18psi
Bosch 023
Sard Fuel Reg
Sard 550cc Injectors
Apexi Power FC
Z32 AFM
FMIC
Pod
Oil Cooler
301hp/224kw @ 18psi
Green Line - is my first dyno 272hp @ 14 psi
Purple Line - 301hp @ 18psi
Big 60-70 hp jump in the mid range
Edited by 45LDE
1993 r32 gts-t
rb 20 (stock internals) 130, xxx k's
Garrett 28-71 turbo on 17psi
Walbro pump
HKS cooler
splitfire coils
Sard 550cc inj
POD
Power FC
Z32 AFM
Full 3" custom made exhaust
Made 228rwkw's (306 hp approx) on boost work dyno
Rb20 powered s13.5
- Un-Opened 9X,XXXkms RB20DET motor,
- Hypergear TR34 440hp ext gated.
- Tuned Length High Mount Manifold
- SARD INJECTORS....
- a fair bit more..... go to my link in signature for all mods..cbf em' typing all haha!
made 227rwkw on 17psi, with ext gate problem...and coilpacks shitting themselves...so should make more than that with new gate setup and my new packs ive got in on same psi..
but since then has been re-tuned to 14psi, while I get a new gate so I can run some more boost etc... and made 210rwkw on 14psi.. :blink:
will keep SAU updated on what happens...
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
