Nee-san Posted July 16, 2013 Share Posted July 16, 2013 God damn reading this thread goes around and around in circles.We need a summary. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6930865 Share on other sites More sharing options...
djr81 Posted July 18, 2013 Share Posted July 18, 2013 God damn reading this thread goes around and around in circles. We need a summary. This is basically it. I have fixed the spewing oil everywhere problem on my RB30/25 and based on my experience this is what I would do on an RB26: Fit 1.0mm oil restrictor. Drill out oil returns to 10mm and relieve all oil returns. Fit Mines baffle kits to cam covers. Install 2 fittings to sump as high as possible run one hose to the top (this is a pressure relief - may also blow some oil) of an at least 2L catch can and the other to the bottom (as a drain). Also vent your cam covers to this catch can (should be very little comes out of them). Then instead of a filter on top of the catch can run a pipe to either another catch can or an oil/air separator and what comes out of that should be fine to pipe into the turbo intake - or if you prefer to a couple of LARGE airfilters. This should deal to your problems (don't bother with fitting on back of head). The second catch can will need to be emptied but not very often. Also (not directly related) minimum baffle kit for sump - better large capacity sump - better still accusump. The things I would add are as follows: Good oil control starts with good blowby control. If you have alot of gas there is no way the oil will return from the head of your motor. I am going with a 1.25 oil restrictor on my next motor. Having an oil return from the catch can is excellent but a one way valve is a really good idea. Make sure the size of the holes in the sump are reasonable - tempted to say atleast -12 but maybe -10 is enough. Not massively convinced by the Mines covers. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6932906 Share on other sites More sharing options...
SilverECR33 Posted July 20, 2013 Share Posted July 20, 2013 ive got the same problem, mines baffles arrived and i will try them out without the other mods ( have the sump already modified to go) but i want to see if the mines baffles alone do the trick. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6936504 Share on other sites More sharing options...
FineLine Posted July 21, 2013 Share Posted July 21, 2013 I lived with an engine bay covered in oil for way too long, We tried 57 different varietys of catch cans, drains, one way valves etc in my 25/30 to no avail, Even tried the pump from the catch can draining oil back to the sump, It was semi successful at best. Leak down tests were always good but it became the bane of my life, a couple of hot laps and we would strike more oil than the caltex refinery. The answer is already in these pages but its damn simple. parts required. RB 26 tappet covers Mines baffles catch can -12 braid or equivelent internal diameter lines from the covers to the can 25 covers are an inefficient desing and too small, the 26 covers have a larger capacity and with the mines baffles are a way better design, the -12 size lines are a must. -10 with only a small amount of oil in the line completely blocks and then just starts a continuous flow of oil hydraulicing in to the can. The larger diameter of the -12 doesnt fill with oil and even if some does go in the line it doesnt completely block allowing the sump to still vent past any oil in the line. I doubt anybody has pumped more oil in to their engine bay than I have over the last 2/3 years and i still havnt gotten used to the idea it doesnt happen anymore. first thing I do after a hard run is pop the bonnet looking to see how much oil I've splashed around but there is none. zip, zilch, zero. Not even in the can itself. In the grand scheme of things its not an expensive fix, particularly for those already wearing 26 covers. For the 25 blokes the 26 covers bolt straight on so grab a set and gitrdone. 1 Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6937576 Share on other sites More sharing options...
fatz Posted July 21, 2013 Share Posted July 21, 2013 yea will be doing what you said as the part time fix see how it goes at pi Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6937725 Share on other sites More sharing options...
XRATED Posted July 22, 2013 Share Posted July 22, 2013 mines baffles in rb26 or modified rb25 rocker covers work 100%. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6938759 Share on other sites More sharing options...
SimonR32 Posted July 22, 2013 Share Posted July 22, 2013 The answer is already in these pages but its damn simple. parts required. RB 26 tappet covers Mines baffles catch can -12 braid or equivelent internal diameter lines from the covers to the can I have RB26 rocker covers, mines baffles, a very effective catch can and -16 from the covers to the can... Still have issues, I get around 300ml going into the catch can every 60 odd sec lap Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6938762 Share on other sites More sharing options...
R32 TT Posted July 22, 2013 Share Posted July 22, 2013 I have RB26 rocker covers, mines baffles, a very effective catch can and -16 from the covers to the can... Still have issues, I get around 300ml going into the catch can every 60 odd sec lap ...and there's your problem. 60 second lap. slow the F down... 2 Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6938773 Share on other sites More sharing options...
Duncan Posted July 22, 2013 Share Posted July 22, 2013 ...and there's your problem. 60 second lap. slow the F down... Oh that was f**king hilarious. Well played Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6938965 Share on other sites More sharing options...
SimonR32 Posted July 23, 2013 Share Posted July 23, 2013 (edited) ...and there's your problem. 60 second lap. slow the F down... Don't you start, I have half the WASCC having strokes about it Edited July 23, 2013 by SimonR32 Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6939570 Share on other sites More sharing options...
djr81 Posted July 23, 2013 Share Posted July 23, 2013 Don't you start, I have half the WASCC having strokes about it This thread needs more beards lecturing Simon about safety. Bottom line: Unless blowby is under control oil issues wont be. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6939915 Share on other sites More sharing options...
fatz Posted July 23, 2013 Share Posted July 23, 2013 Lol but why build a engine when it still runs fine Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6940253 Share on other sites More sharing options...
Jazzadub Posted July 27, 2013 Share Posted July 27, 2013 Apologies if this has already been covered! I am looking to install a Tomei Oil Pump and I believe it flows more than the other aftermarket pumps listed in the table on page 2. The car is primarily street, and will be taken to the track occassionally. Engine is RB26 so has solid lifters. Would I be right in thinking that a 1mm restrictor would be the best compromise? Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6946141 Share on other sites More sharing options...
KiwiRS4T Posted July 27, 2013 Share Posted July 27, 2013 Most pumps produce more than enough flow. You would be buying the Tomei for its longevity and ability to be adjusted from outside. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6946381 Share on other sites More sharing options...
Jazzadub Posted July 28, 2013 Share Posted July 28, 2013 Thanks for the reply. My question was regarding what size restrictor to run to account for the increased flow of the Tomei. Being solid lifters I understand not much oil is required. So would that justify me using a 1mm restrictor in conjunction with a Tomei pump? Or should I stick with a 1.25 or a 1.5mm? Even at the lowest setting on the Tomei I believe that they flow more than any other pump listed in the table, primarily due to the larger gears. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6946570 Share on other sites More sharing options...
r33_racer Posted July 28, 2013 Share Posted July 28, 2013 A single 1.2/1.25 will do the job. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6946574 Share on other sites More sharing options...
Jazzadub Posted July 28, 2013 Share Posted July 28, 2013 Thanks man - exactly what I was after Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-6946849 Share on other sites More sharing options...
ToF Posted September 20, 2013 Share Posted September 20, 2013 Sorry if this has been covered. I've been through a few pages here and there and found a few catch can diagrams but does anyone an mspaint flow diagram of the best/recommended catch can setup (that most agree on after 51 pages )? Thanks guys. Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-7029215 Share on other sites More sharing options...
KiwiRS4T Posted September 20, 2013 Share Posted September 20, 2013 Don't do MSpaint but can do English. IF you have an oil control problem apart from the other measures here is what to do catch can wise: Run 2 half inch hoses from as high as possible in the sump on the inlet side to a catch can mounted at battery level - one hose to the top and the other to the bottom (for a drain so include an optional one way valve). You can combine the hoses from the cam covers and run them into the same catch can (ideally a well baffled catch can). Do not vent the catch can to atmosphere but run a hose from the top of the can to the turbo inlet. Ideally you would include an air/oil separator in that line or alternatively a second catch can although neither may be strictly necessary if you are not getting oil in the line to the turbo inlet. Sorry if this has been covered. I've been through a few pages here and there and found a few catch can diagrams but does anyone an mspaint flow diagram of the best/recommended catch can setup (that most agree on after 51 pages )? Thanks guys. 1 Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-7029218 Share on other sites More sharing options...
Shoota_77 Posted September 21, 2013 Share Posted September 21, 2013 I agree with the above. This is my pretty picture I just made. With the hoses coming from the rockers you can either do two hoses if you have enough inlets on your catch can or or like Kiwi says you can run one hose (on mine I joined the two together with a tee piece and ran one hose off the middle outlet of the tee to the catch can. 1 Link to comment https://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page/51/#findComment-7029361 Share on other sites More sharing options...
