My rant is nothing compared to cancer... but I have a major issue when people pull out infront of me when im on a steady stretch at 70km ish... D***head in his pt cruiser gave me about one car's length to stop (on wet road). Consequently, he sped off in his shtbox so I wouldn't clip his car and left me skidding down the street nearly having a heart attack. THEN when I pulled up next to him at the lights - he laughed. :dry:
ALSO, the idiot that stood right behind me last night at BP Morley trying to look over my shoulder when I was putting my pin number into an eftpos machine. Maybe he thought he was funny, but then when I turned to give him a filthy look he smiled - all friendly n sht. :P:P:O
Gave him the finger when I was pulling out and it made me feel a lot better :)
On a similar rant - a stupid soccer mum pulled out in front of me whilst going down greenmount hill
(gt eastern hwy). I had a semi trailer on one side and her arse end about to join with my front end. Lucky for good skyline brakes. And guess what? Not a single f**king car behind me. She must be in a rush to die.
wgmg
builders (are we seing a patern here) who call you i want this done now five or six times a day itll get done as soon as i can get to it even sooner if i dont have to keep answering the phone you d*&$head!
That's because coffee is a diuretic
its atually the milk itself in them thats the diuretic along with 5000 chemicals used for the pasturisation and homogination process.
me is a milko some has learnt these things lol
Oh i just gotta add to this:
Dumb asses in pub and public venues that set they plasma screens to 4:3 stretch. Isnt it obvious that the show is in 4:3??!??! dont u see that ppls heads are fat? we know the thing is 16:9 so play a 16:9 source you morons.
Oha nd ppl who give "the finger" at random. Like it achieves something apart from spreading hate. :O
Clients! Why do they insist in trying to micro manage the job they pay you to manage for them...I could be on a beach somewhere but nooooooo " Mr.Keets can you add that to your action log and liase with some faceless klown blah blah blah" Die empire building ass master!
Sub humans that pull out infront of me on the way home from work. Die run of the mill sub human!
Christina Aguleira and any of those new skool R&B types that insist on turning one vowel into an opportuinty to demosntrate their less than stellar ability to span 2 octaves with their whiny voice... and for gods sake put some weight on ya bulemic skanks, shoulder blades are not sexy :(
Oh and stupid ppl that cut me off in traffic and dont notice me flashing at em cause they have no rear view mirror and both their side mirrors ar looking at the side of the car. This woman could not see behind her car at all. That is the epitome of a driver that doesnt give 2 s***s about the world.
Christina Aguleira and any of those new skool R&B types that insist on turning one vowel into an opportuinty to demosntrate their less than stellar ability to span 2 octaves with their whiny voice... and for gods sake put some weight on ya bulemic skanks, shoulder blades are not sexy :D
And that my friend...
Wins you the!!
That Really Grinds My Gears Grumbler of the Week Trophy!
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
