Could be going to pick up a 32 GTR within the next week or so.
Has a standard setup, and i am looking to throw on some GT-SS turbo's pretty much as soon as I get it.
Ive have seen on a coulpe of other 32 GTR's that people are making approx. 260awkw (290rwkw?) on about 1.2 bar?
Im just wondering now, am I able to make that same power safely? What are the limits of the r32 gtr's standard Injectors and fuel setup as the last thing I want is detonation.
Cheers,
Brett.
Edited by Brett_A
  • Replies 41
well firstly if you are going to push the stock pump and injectors a bit there a few things i would do. firstly have your injectors removed then cleaned and flowed and re-installed (highest flowing to the back, and lowest at the front). Then i'd reccomend using a power FC or similar so that once you put on the turbos you can have the car tuned to suit that much airflow. put on a fuel pressure gauge whilst it's on the dyno and look for any tapering off of fuel pressure up in the revs (indicating pump out of flow or failing). Providing you do all this, with a fairly safe (rich) tune you should be able to get 260awkw no problem, injectors will be on 100% duty though so just keep an eye on the AFRs on the dyno and the fuel pressure.
enjoy :(
enjoy :D
Ok cool. I was planning on getting a power FC as well. Have about 6k spare, so I figure I should be able to get some GT-SS turbo's, power fc and a tune and maybe a little left over for new injectors, otherwise will just rebuild them like you said.
If I do opt to upgrade the injectors, should I aim to do the pump at the same time or are people able to achieve a fair bit more power with the standard pump?
stock pump will be good for well over 300rwkw...
injectors depends on your tune/fuel pressure etc... You tuner would be the best person to ask these questions - he's the one who knows what he's going to do.
What state of Australia do you live in? :)
Queensland. But im all the way up in Cairns with limited tuners.
My plan IS to upgrade the fuel setup so I can have more boost, but was just wondering because I dont have the biggest budget.
Thanks for the replies :D
Edited by Brett_A
forget boost for a minute, do you have access to premium 98 ron fuel all the time? if not then this is certainly going to impact the tune and power you make
Yeah mate, thats all good. Using BP ultimate in my fully sik VL turbo at the moment.
Im actually thinking about heading towards the hks 25/30's instead of GT-SS's.
Ive been reading a few threads, and peoples opinions are that they tend to run out of puff up in the top end. And if my goal is to achieve 350awkw in the end, the GT-SS turbos would be around their limit wouldnt they?
GT-SS will be to small for 350awkw - they are more suited to around 300-320kw.
If you want 350 you will need 2530, etc
PS - can anyone tell me the size of stock R34 GTR injectors???
youll find that going from an rb30et to an rb26 in terms of response will be a big step down even if the 26 is stock turboed. now, planning to put on 25/30s will make it a even more laggy and a huge shock. thats ok if you dont mind the lag, but if you plan to drive the car mainly on the street then you may be a little disappointed. if you like that low-mid torque of the rb30, then stick with the GT-SS turbos as they offer similar spool to the stockies.
i know i noticed a big response difference with a stock turboed 32 GTR after driving a mildy modified 30et and stock rb25 for the last few years.
i would suggest you upgrade the pump and injectors at the same time. for me it would be hard to go past a set of sard 700cc injectors and a nismo pump. pefect match for each other. it's piece of mind on a tuned 32 as your 32 pump is starting to get on a bit in years...
Beer Baron,
So its perfectly normal to see 80% duty or there abouts on the stock rb26 injectors with around 230rwkw?
mmmm, you thinking what i'm thinking Joel?
For you other guys i'm getting 85% duty cycle on the power fc with GTR injectors and GTR fuel pump! (228rwkws)(RB30DET)
Edited by mr_rbman
Beer Baron,
yep. no problem at all. dont forget that as there is no feedback to the ecu when giving it some the duty cycle is just an output caused by the number plugged into the fuel map at that load/rpm point. In my GTR with quite a rich tune, i can brush 100% at 253rwkw. as long as the AFRs are good and fuel pressure is not dropping off up top (sign of weak pump) it's not a major concern unless of course you want more power which will need more fuel.
but short answer: 80% duty, with 230rwkw with safe tune sounds about right to me :laugh:
but short answer: 80% duty, with 230rwkw with safe tune sounds about right to me :P
bugger, i was hoping to get 270-280rwkw's from mine! With a FPR!
    • Here's a boring history lesson on number plates People want illegal spacing to make their plate more readable, if mine was J2X BK, anyone who knows about the car would see that its spelling JZX. Years ago third party plate manufacturers could alter the text to make it look like something else, nowadays the computer software is locks that ability (well, ours does at work) Up until 2001 the first letter of a number plate represented the year of the vehicle, for example A would be 1983. (pre 1983, the format was backwards, so the year letter was on the end). Followed by 3 random numbers and 3 random letters. Things started to get complicated at the end of the 90s where T and V were 1999, W and X were 2000 and Y was early 2001. From 2001 they introduced a new 'layout' where the first two characters are letters, this represented where that vehicle was first registered in the country. The letters corrosponded to a region in the country. Some regions had a large number of codes, where as some only had a couple (despite being large in physical land size) Next are 2 numbers to indicate 2000s. So it went from: Y (March 1999 > Aug 2000) 51 (Sept 2001 > Feb 2002) 02 (March 2002 > Aug 2002) 52 (Sept 2002 > Feb 2003) etc etc When the 2010s got here, the numbers changed again, going up by tens 10 (March 2010 > Aug 2010) 60 (Sept 2010 > Feb 2011) When the 2020s arrived it went to 20 (March 2020 > Aug 2020) 70 (Sept 2020 > Feb 2021) etc As for personalised plates, you're not allowed a registration that makes the vehicle look newer. Take my 110 for example, its a 2004 car so I can have any available plate upto 04. I can't have a 54 because it was manufactured in August 2004. Which allows me to have a J plate, because its older (if that makes sense)
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
