I told you they were coming! It's still a small % of us but they are coming!
I'm pretty sure they jumped in through the same window Aaron came through!
Edited by Jetwreck
Maybe you can rise up as their leader. They are all gunna want Epic wings like you and then you can change them for good,
Just like the soup nazi!
NO MORE CAR WORK FOR YOU!!!
Here's mine:
Owned since March 2010 - purchased from Japlink with 39K and now nearly 139K.
Mods include:
Hdi FMIC (installed by Dale), B+M transmission cooler sandwiched b/w FMIC and radiator (installed by Japlink), plenum spacer (installed by Dale), Selby sway bars front and rear (BG organised by Dale and installed by him), Dale's front chassis brace (also installed by him), Jetwreck's GB rear chassis brace (installed by Dale), BC BR coilovers (installed by Dale last Dec - with thanks), Brembo brake upgrade (installed by Japlink), transgo shift kit (installed by Jetwreck in the bro' garage), Scotty's 3" dump pipe and a custom 3" exhaust (installed by Japlink), air horns above the FMIC and pair of LED fog lights (both installed by Japlink), 19x9.5 +20 offset (bought from jasevr4) shod with Kumho KU31 245/40 (from Taleb Tyres Arncliffe),
Dude! That looks great, nice one.
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
