Hi Marko,
1) The Nismo Kill Switch Cosmetic Lighter is a display item - but genuine Nismo
There's a recent WtB thread of how someone wanted one and an SAU Trader said he still had some left, even though they're discontinued.
Even the "Nismo" logo is the old type. Matthew (God_speed) noticed (since his eyes are better than mine), that there's a "Nissan" stamp on the collar too supposedly to make counterfeiting more difficult.
2) Steve-0 (N1GTR) mentioned to me that the "N1" sticker existed, so I sourced high and low.
It's the same font and brushed aluminium background as the "V-Spec" sticker on the rear quarter of the R34 GT-Rs.
Yes, there are many other differences on the R34 GT-R N1 too.
About 22x
Should I list them off?
More importantly you got to keep the flare, ha. It would be interesting to find out what options were available . I have a different front bar , orange indicators and no bagdes except for the usual GTR ones on the body. Also with all the log book and service stuff I got a pink safety driver sticker, ha, ha
Characteristics incl Specs of R34 GT-R N1 include...
1) N1 Engine Block
2) N1 Oil Pump
3) N1 Turbochargers
4) N1 Water Pump
5) Different Horns
6) No Air Conditioner
7) No Sound System - Just a Plastic Panel
8) No Speakers - Just Taped Over Cavities
9) No Driver's Door remote Control Opener or Motor
10) No Folding Rear Vision Mirror Control Button or Motor
11) Rear Vion Mirror housings Painted Black
12) Thin White (QM1) Body Paint down to 90 microns
13) Plastic Centre Console Lid
14) Plastic Handbrake Handle
15) No Cosmetic Mirror Behind Sun Visor
16) Thin Window Glass
17) No Privacy Glass
18) No Space Saver Wheel
19) No Rear Wiper Control or Motor or Blade
20) Rear Window With No Accommodating Hole for Wiper
21) No Rear Fog Light
22) Extra Reversing Light
23) Door Entry/Exit Lights Removed But Lenses Remain
24) Extra Large Oil Cooler and Piping (edit by kimbod)
25) Larger Rear Brake Discs (edit by kimbod)
26) No Clear Coat on Body Paint (edit by kimbod)
Not sure if this is the correct place for this post (I'm a newbie) but my GTS2 was stolen this morning from Ascot Vale Rd, Melbourne. Build #112. Been in the family since new and I'm absolutely gutted to see it stolen, please keep an eye out!
  • 3 weeks later...
Hey Yall
Is there a way of telling a BNR32 Vspec 1 to a Vspec 2 by the engine tags. Have been told that a Vspec 2 on a 32 will be something like this BNR32XXX-XXX8......if there is no 8, it is a Vspec1. If someone can confirm this it would be great.
Cheers
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
