45490E44-5581-44B9-920D-03534290D6B9-495
D21BDD3F-8E83-42B2-B773-5F877E35093D-495
8 hours of polishing later.
Jezz i love those rims! if only they were easier to find!!
What offset are they mate?
I have the enkies 18 x 10.5 +12 i think they are. Im thinking i want to fill the gaurds a bit further....
Thanks man.
They're 18 x 10 + 12 with 285 RSR's on them. The tyres are a tad wide for those rims.
They definitely are not an easy rim to find. So damn light at 7.45 kg.
Ah maybe thats why they look like they fill ot the gaurds better then mine. im running 275s. im thinking before i change rims i should try running some 295ish and see if that makes it look like it fills the guards
I think we`ve been through it before.
It was an inside joke with my mates, they have a soarer and supra.
Ironically both lemons, hanging a toyota badge is like saying to them "do you need me to tow you around, mate"
just shit stirrin`
Same as my mate having a piston hanging of his rx7
just shit stirrin`
ahhh my other love, shit stirring! Go the whole way and rip off the Nissan badges and replace with them with Toyota!
Lowered the old girl and debadged the gtr rims
That looks really good! Almost looked like a GT-R for a second there, probably the front lip and wheels. What size tyres you running? Did you have to roll guards? Might get a set of those for myself, and PC them black!
Edited by colourclassic
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
