Tomei didn't do a lip for the facelift gtst. The lip on your gtr is a Tomei lip though Danny14.
It looks as though it's a Nismo lip that's had the centre section filled in to make the bit that juts out go the whole way along.
Its definitely not the nismo lip. this is what it looked like before the modification:
Red r33 is sexy. What's the specs of the front wheels #A-B_DR/fT-KinG!!
Cheers bud :)
Front wheels are 18x9 +17.
Yes, that is a Nismo lip. The lip you are thinking of was a dealer catalogue option, although people refer to it as such it is not a Nismo lip. The lip in that picture was offered by Nismo from 1997 onwards, I'm not sure when they stopped offering it though. I'll take some pics of my R33 Skyline Street Parts catalogue tomorrow.
Having just sold my series 2....this car makes me want to cry, but everyone should see it.
So here's a shameless repost :)
Yeah my was my bros car he bought that lip and fitted it . One of a kind I spose I havent seen any 33 gtr with that lip anywhere
That's cool. Love the extra little bit of dish from the 10", just the right amount - not too much. I've got some xd9s in bronze at home waiting for rubber, have gone with 18x9+20 all round. So keen to get them on!
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
