Hey people this is my 1st post thought it would be a good place!
YEAR: 1984
MODEL: Skyline GT EX Facelift (with RB30DET)
BODY TYPE: Sedan
COLOUR: White
Edited by R30-RB30DET
for those of you with HR31's here is a link to the register from the R31 Club...
http://forum.r31skylineclub.com/index.php?topic=19090.0
please leave the details in both this thread and the one on the r31 forum.
Edited by rsx84
post-32896-1162953263.jpgHey all,
I just purchased a 1984 MR30 Hatch 'Ti' auto, stock standard L24e, only 130,000km...
Needs a few steering parts and tyres for RWC
The steering bits might be hard to come by... 'idler arm and ball joints are worn/loose"
The engine is pretty good, need more power thought of course! looking at a fully ported L28 conversion, with hope of a turbo later on, or a RB20DET, ( which might be easier...)
Will post up some more pics later....
And i really need help with these steering parts!
YEAR: 1989
MODEL: nissan R31 skyline series 3
BODY TYE: SEDAN
COLOUR: white.
MODS:
full sound system.
king springs low.
hyb shocks.
dba sloted disc front and rear.
k&n filter CAI intake.
adv timeing.
hight tech exstractors
2.25" exhaust.
chiped computer.
LSD
17x17 aus car bournouts.
YEAR: 1978
MODEL: C210
BODY TYPE: Sedan
COLOUR: Orange
Just fitted GT-E Tail-lights :(
Year: 1990
model: r31 GX
body type: wagon ^^
colour: white
Did have:
Year: 1983
Model: KHR30 GT-ES Paul Newman Version
Body type: Coupe
Color: Blue Pearl
Swapped for
Year: 1984
Model: GT-EX Turbo
Body type: Sedan
Color: White
Matt,
I don't know wether you want to include this as relevant, but my PNV is colour code 441, which is 002 white over 028 grey metalic.
And George Bryants old car that you list under ??? is colour code 434, which is 111 Dark Blue over 028 Grey metalic.
And although some are plated LATE 83, ALL Paul Newman Versions were manufactured in series 2 livery and marketed and made for the 84/85 market ONLY.
Cheers, D.
Matt,
Cheers, D.
that kind of info is better listed in a thread devoted to the PN version...
Cheers anyway, Matt...
YEAR: 1988
MODEL: Nissan R31 Skyline Silhouette GTS1 #166 of 200
BODY TYE: SEDAN
COLOUR: Classic White.
MODS: Stock .... NSV optioned... (16" rims, 2.25 exh. Extractors, Bilstiens, bigger brakes, sg.1 cam, scheel bucket seats... etc)
The owner of:
Year: 1983
Body type: Coupe
Color: Blue Pearl
Is drift_orcons from www.skylinesdownunder.com
the car is located in Christchurch, New Zealand.
I know this isnt a spotted thread but these are worth a mention
today I saw 3 old skylines of interest
a silver R30 sedan with a big nismo sticker on the windscreen and a massive fmic, saw it in sherwood
theres also a yellow c110 4 door in pretty decent nick thats usually around rocklea
and this white c110 2 door that ive seen around a bit in the centenary area. no badges but it has s3 gxe r31 hubcaps sprayed black and some old japanese brand name looking stickers on the front
Just arrived home today with
Model.........MR30, 1984
Type .........Ti Sedan
Engine........L24e, 5 speed manual
Colour........Gold.(once upon a time)
Shes not registered at present, but body, brakes , running gear are all AOK. Needs a tickle in the electrical/ecu dept to get running, then of for RWC and Rego.
This week I hope as I'm for a shoulder recostruction on the 11th. Dec.
I'll let you know how it goes.
Edited by 66yostagea
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
