  • Replies 50
Calder twilight meet. I want to get a lipstick camera under my car looking at the wastegate...may give some good footage :/
Bris, I have the cameras to do this, I'll come out and we'll set it up.
Yes. Same as the Falken Azenis RT 215 (or similar) - R compound, but street pattern.
Just a note for 2007. The committee will review the classes and tyre classifications to make it a bit easier for you guys to understand. Info will be posted before first event (I hope)
This will be my first real go at Calder. Looking forward to it. Hopefully now i have the smaller exhaust housing and more then 7psi the car is fun at Calder (Street tyres though :( )
I'm considering a return in the Volvo.. T.B.C
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
